Question about Nikon Coolpix L11 Digital Camera
My battery barely lasts ten minutes
I have a Nikon Coolpix L11, barely six months old. But my battery barely lasts ten minutes
  • 4 Answers
SOURCE: Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
Posted on Jan 12, 2008
SOURCE: lens error
i didnt drop mine i turned it on and it had this problem what do i do??
Posted on Feb 17, 2008
Rhythmicity
  • 4 Answers
SOURCE: nikon l11 and mac drivers
You can download the drivers from here. On the page, it says that the driver is only supported by Windows, though I'm pretty sure it works with Mac as well. I think the driver you need is PTP. There's also a setting in the camera for this, just change it in the Set Up > Interface > USB menu. Can't say this is 100% the solution, since I don't have a Mac system available to me.
Good luck.
Posted on Mar 06, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: Nikon Coolpix L11 camera
FIND THE USB OPTION IN YOUR CAMERA MENU AND SELECT MASS STORAGE OPTION, THAT WILL ALLOW YOU TO CONNECT & VIEW THE PHOTOS LIKE A REMOVABLE HARD DRIVE OR JUMP DRIVE
Posted on Aug 11, 2008
robmcd27
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
My computer does not recognize my camera after hardware is added. (Nikon Coolpix L11). This camera model is not given as a choice in the wizard.
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
May 11, 2011 | Nikon Coolpix L11 Digital Camera
My nikon coolpix L11 camera keeps turning off
Sounds like a bad battery, when the battery gets old, it turns the camera off....
Mar 16, 2010 | Nikon Coolpix L11 Digital Camera
My Nikon coolpix L11 battery door does not close properly, or, the battery compartment is faulty. The camera has no dc power. Help!
Try using a dc adapter and pressing on the battery cover if it is loose. If it is loose go to bocaphoto.com for replacement door.
Sep 26, 2009 | Nikon Coolpix L11 Digital Camera
Battery Cover for L11 Coolpix
Take the 7 screws out around the edges, place a flat tip screwdriver between the battery door and the case, pry the case apart just enough to get the pin out the side using a pair of needle nose pliers, remove the old door and put the new one in place and reinstall the pin, squeeze the case together and reinstall the screws.
Aug 24, 2009 | Nikon Coolpix L11 Digital Camera
Keep putting new batteries in Nikon Coolpix L11 but keep saying low battery???
Check if the charger is working. If yes Firstly, make absolutely sure that you have a pair of fresh HIGH QUALITY batteries, in fact go and buy a couple of duracells. Digital cameras are notoriously power hungry and it is very possible that a pair of cheap standard batteries will not be able to run it for more than a few minutes. Check that the terminals of the batteries and the camera are clean. If none of this works, and you did have fresh alkalines or equiv. then it will have to be returned for repair.
Thanks.
Jun 18, 2009 | Nikon Coolpix L11 Digital Camera
Nikon coolpix l16, not taking pics
Take out the media card, then do a factory reset.
Jul 06, 2017 | Nikon Coolpix L11 Digital Camera
Power going away..
Have you tried stretching the contacts upward to hold the battery more securely?
Jul 23, 2008 | Nikon Coolpix L11 Digital Camera
Coolpix L11
yep it's $100+ to get it fixed. i've read about this problem and it was fixed before, check this out.
http://www.fixya.com/support/t225788-fix_stuck_lens_nikon_coolpix_l11
good luck
Jun 24, 2008 | Nikon Coolpix L11 Digital Camera
Batteries wont work on my Nikon L11
Hello
i have used Digipower AA rechargable and Everready AA rechargable batteries without a problem lasting a long time in this model.
you may have a problem with the battery charger itself.
batteries i am using are rated at 2400-2500 ma
in the menu button, select shooting menu - set up - scroll all the way down to battery type, select the battery type you are using and press ok in the center of the button.
you can use the coolpix nimh selection for other rechargable brands.
May 31, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
