Question about Samsung SCH-a870 Cellular Phone
My samsung a870 is locked in nam2 & none of the default codes seem to work. is there a code to unlock & erase my phone?
  • ohhhbaby888 Feb 11, 2008
    I have a samsung-a950 and it won't let me access anything on it. There is a lock code needed, but nothing works.
    A little pop up stays up on it and it says "inital programming needed. "
    This is a new problem after i accidently switched it from NAM2 to NAM1. (and it powered off)
    someone please help me!!!!
I believed that it changed the last four digits of you phone number and the default number would probably be the same last four digits. Try 0000 and if that doesn't work, then you might have to take it in to your service provider and they should be able to reset your phone for you. Also, below the batter, there is a 1-800 number you can for information.
Posted on Feb 07, 2008
I have a samsung reality. i was fooling around with the settings & set it to NAM2. it's now locked i need a 4 digit code. i've tried all the online suggestions nothing works. i've been up for 4 hours...
Using the default "last four digits" unlock code will not work because switching to NAM2 changes your phone number, and hence changes the default unlock code. You have to find out your new phone number (and new unlock code) under NAM2. Do this:
  • Get to the dialer screen.
  • Dial #43574357* (#helphelp*)
  • Tap "1. system info"
  • The top two entries, MIN and MDN are your new number. Usually they are invalid phone numbers (000-000-????) but the last four digits are your unlock code. Write them down or remember them.
  • Get back to the unlock screen, type in the code.
  • Go directly into the menu and change back to NAM1
  • Don't do that again. :)
Sep 17, 2010 | Cell Phones
Isamsung glyde phone locked in nav 2 mode
I'm not sure if this is really necessary for anything other than Samsung phones, but I've only ever seen this issue come up when dealing with Samsung phones. Here's a scenario: You're messing around with the various settings in your phone's menu, and you switch your phone to NAM2 in the process. Your phone resets, and you find that your phone is now locked. Unfortunately, your normal lock code doesn't work. What do you do?
First off, you should probably understand what NAM1 and NAM2 are. Basically, think of them as containers. Each of these "containers" holds a phone number. Yes, you can have two phone numbers on a single cell phone. I generally don't recommend it, though, as you can only have one of the two numbers active on the phone at any given time, meaning that you'll miss all of your calls on the number whose NAM you're not on at the moment. Also, NAM2 generally can't accept over-the-air programming, so you'll need to manually program your account information into it, and you'll need to have updated roaming information loaded into your phone in one of your carrier's retail stores (assuming that they even support NAM2).
So, why am I telling you about NAM1 and NAM2? Well, your default lock code (assuming that you never specified your own) is generally going to be the last four digits of your phone number. Problem is, NAM2 doesn't have a phone number in it by default, so you'll need to somehow figure out what the default lock code is set to on NAM2.
Secondly, you'll need to locate a hexadecimal code, usually found inside of your phone's battery compartment. There are two different types of hexadecimal codes that you'll need to be on the lookout for: ESN and MEID. Now, Samsung phones generally don't have these numbers labeled, but it's easy enough to find them. An ESN in HEX format will be eight characters long, whereas an MEID in HEX format will be fourteen characters long. MEID's tend to begin with the letter A from my experience.
Now, depending on which type of hexadecimal code you found in the previous step, you'll need to take one of two different paths in determining your unlock code...
Let's start with the easier path, the ESN...
Thankfully, all you need for this one is a scientific calculator. If you're using Windows, then simply launch Calculator. Once you've launched Calculator, you'll want to choose View > Scientific from the menu bar.
Once you're in scientific mode, click on the Hex radio button, then enter the eight-character ESN.
Now, click on the Dec radio button to convert your ESN into DEC format. Now, do bear in mind that this won't be the same as the ESN number in DEC format on your phone's battery compartment label. That's why only the ESN in HEX format is important. Anyway, the last four digits of the resulting number are what you'll want to enter in order to unlock your phone.
Now, let's move on to the slightly more involved path, the MEID...
Really, the only reason that I consider this to be harder than the previous path is because it requires a tool that isn't available on most computers by default. Basically, you'll need to find a hash calculator, specifically one that's capable of working with the SHA-1 algorithm. You don't really need to understand what the SHA-1 algorithm is in order to unlock your phone, but - in case you wanted to know, anyway - I suppose that it'd best be described as a method of making pieces of code more secure. SHA-1 and other similar algorithms simply make changes to code in order to make said code more secure.
Anyway, I'd recommend HashCalc, as it's free and easy-to-use. Once you've downloaded and installed HashCalc, launch it. Change the Data Format option to Hex String, then enter your fourteen-character MEID. Be sure to check the SHA1 checkbox, then click on Calculate. See that long code that appeared to the right of the SHA1 checkbox? Write down the last six characters of it, as they'll be vital in determining your lock code.
Now, this next part will look more than a little familiar. Basically, you'll want to have a scientific calculator for this, just as we did for the first path. Again, in Windows, you can simply launch Calculator and choose View > Scientific from the menu bar.
Once you're in scientific mode, click on the Hex radio button. There's a problem, though: We don't have an eight-character code to put in as we did before, and we need an eight-character code in order to figure out our lock code. Well, thankfully, the first two characters in the eight-character code are always going to be 80. As such, your eight-character code will be the number 80, followed by the six characters that you wrote down after using HashCalc. Now that you have an eight-character code, input that code into your calculator.
Now, click on the Dec radio button. As before, the last four digits of the resulting number is your lock code.
Dec 23, 2009 | Samsung Glyde SCH-u940 Cellular Phone
I recently switched my NAM for NAM1 to NAM2 at first everything was fine it rebooted and everything but at start up it asked me for a four digit unlock code i was like what the heck i dont have an unlock...
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Oct 20, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I NEED A UNLOCK CODE FOR MY SAMSUNG SCH-a870 SERIES SCH-a870 601-941-3981 MODE NO#SCH-A870 FCC NO#A3LSCHA870 NOTE: CAN'T GET IN MY PHONE
To unlock your Samsung SGH600 mobile here is a code *2767*3855# it will reset eprom.which removes SP lock.
For A series samsung the unlock code is
*2767*637#.this code reset your mobile.
Feb 21, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Locked samsung sch-a870 phone on roaming status wont unlock
the code should be the last four digits in your number and if not take your phone to a mobal carrier store or reset it
Nov 02, 2008 | Samsung SCH-a870 Cellular Phone
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
I have a samsung SCH-A870 and i forgot my unlock code and cant get into my phone at all
samsung default code is 000000
if not enter 0's until the ok request comes up
Oct 24, 2007 | Samsung SCH-a870 Cellular Phone
Samsung SCH-a870 Cellular Phone Logo
169 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
