Question about Apple Powerbook G4 17" 1.67 GHz SuperDrive Mac Notebook
I have no sound from my built in speakers or from my headphones, my volume was working properly earlier but stopped suddenly. I've checked the audio MIDI and nothing is muted but I still have no sound.
All right people have a bunch of really short solutions to these problems that aren't really solutions on this site. They just seem to be like yo somethings wrong with your computer. It might be your firmware. Well try this... Zap the PRAM
1. Shut Down.
2. Start up and hold cmd + opt. + p + r
3. While holding this the computer should start up and
automatically restart your computer again while still holding it.
Upon the second start it should Make a Chime and the sound should come back. If not then its not your firmware. It Might be that you threw away your built in speaker prefs. or the speaker shorted and u need a new one. To test this plug in your headphones to see if they work. If not then you have an internal software problem and you should take it to a technician. He may have to reload your system so back everything up. And be ready with the Mac start up discs that were given with the computer. Hope this helps. I'm going through the same thing right now with my G4 and am at the point where I need a tech. I may just buy a new Comp. (I love my G4 though)
Posted on Feb 17, 2010
    Problem Solver:
  • 12 Answers
There are two things too this,  you either have to restart your laptop, or something went wrong which casued the speakers to break from inside
Posted on Nov 15, 2009
  • damueng2008
    damueng2008 Oct 23, 2012
    how much it costs for a new internal sound system
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
Tip
How to Troubleshoot a Mac Computer With No Sound
When troubleshooting sound problems on Macs, you can find thefix quickly if you isolate the possible problems first. Regardless of youroperating system, it will make things easier if you can narrow down thepossible points of failure by momentarily unplugging any sound devices.Following simple change of sound settings and testing internal sound alerts canfix the problem.Instructions<br />1.<span> </span>GeneralTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch iTunes or another media player applicationand have it play continuously to start troubleshooting. Make sure the volume isnot muted or disabled. Move the volume slider on the menu bar up and down. Youcan also use the keyboard's Increase and Decrease volume buttons (usually F4 todecrease and F5 to increase the volume). <ol> <ul> <li>2 </li></ul></ol> Unplug any headphones that might be connected toyour computer's headphones port. If your <a href="http://www.ehow.com/computers/">computer</a> has internal speakers,unplug any external speaker plugged to the audio port to isolate the problem.Check if sound is working properly through the internal speakers. <ol> <ul> <li>3 </li></ul></ol> Go to System Preferences on your Mac menu. Clickon the ''Sound'' icon, under the Hardware section. The Sound settings pagedisplays three main buttons: ''Sound Effects," ''Output" and''Input." Click on the ''Output'' tab. Select the ''Internal Speakers,Built-in Output'' option, and raise the ''Output Volume'' at the bottom of thatwindow. Check if sound is working properly. <ol> <ul> <li>4 </li></ul></ol> Go to the ''Sound Effects'' tab, and make sure the''Alert'' and ''Output'' volumes are up and not muted. Select ''InternalSpeakers'' from the ''Play alerts and sound effects through'' drop-down menu.Click on any of the Alert Sounds in the left column and test to see if theysound as you change from one to the other. Check if sound is working properly.2.<span> </span>GaragebandTroubleshooting<br /> <ol> <ul> <li>1 </li></ul></ol> Launch GarageBand. A default piano track willappear. If it doesn't appear, click on the ''Track'' Menu and select ''NewTrack''. Choose a Software Instrument from the dialog box, and then choose aPiano from the selection of Instruments. <ol> <ul> <li>2 </li></ul></ol> Click on "Menu." Select ''Preferences''and click on the Audio/MIDI tab. For Audio Output, and Input select thecorresponding ''Built-In Output'' and ''Built-In Input'' from the drop-downmenus. Confirm the action. <ol> <ul> <li>3 </li></ul></ol> Click on the Piano track. Under the ''Windows''menu bar, select the ''Keyboard'' option, or press [ Command + K ]. A keyboarddisplays. Click on any of the keyboard keys. You should hear sound coming outof your internal speakers.<br />Make sure there is no headphone jack inserted in the computer. If sound doesnot work, try quitting the application and launching it again. <ol> <ul> <li>4 </li></ul></ol> If any of the previous steps do not fix the soundproblem, reboot and try again. <br />If you see a Disabled Volume alert when you try to raise the volume, alsoreboot. This is a known bug in Macs
on Jan 21, 2011 | Computers & Internet
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | Computers & Internet
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
The sound stopped suddenly. No sound through built in speakers or through external media such as headphones. Nothing.
irst right click my computer clickproperties then click hardware then device manager and in the click sound vedio and came controller and see wether the driver is installed properly if you see question mark in the driver or the driver not installed properly reload your sound driver which came with the motherboard if the drivers are installed properly then click start settings control pannel then click sound and audio device then click volume and move the slider to high then untick the mute button if ticked then restart the computer
Apr 22, 2011 | Toshiba (PA3390U-1MPM) Sound Card
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
No sound
To troubleshoot a no sound issue first you must check your device manager to make sure the audio device is installed properly.
To goto the device manager in XP:
Right click my computer>Properties > Hardware Tab > Device manager.
Look for your audio device in the list under "Sound, Video and game controllers". If it has a exclamation mark or question mark beside it you will need to download the most recent drivers from the manufacturer's website.
Next step is to goto
start>programs>accessories>entertainment>volume control
make sure that Wave nor Master Volume is not muted, and both are turned up.
Third step is to check for onboard volume control, there might be volume controls on the system hardware itself.
If you say that external speakers work and not the built in speakers, then the headphone jack that you plug the speakers into may be defective. As it is always detecting something plugged into it and never turns the internal speakers on.
Mar 24, 2008 | Computers & Internet
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Apple Powerbook G4 17" 1.67 GHz SuperDrive Mac Notebook Logo
263 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
