Question about Apple iPod 4th Generation MP3 Player
All my ipod shows is outlet with a wall plug in it has ben like this for a week plez help i did plug it in to the a wall charger and nothing happened
4 Suggested Answers
minteker
  • 52 Answers
SOURCE: ipod only shows outlet
You could try resetting the ipod. On my ipod photo, you have to turn the hold switch on then off, then hold down the Menu and select buttons for 10 sec's. It takes a few tries :>.
Check out:
http://docs.info.apple.com/article.html?artnum=61705
Posted on Mar 11, 2008
  • 16 Answers
SOURCE: ipod show plug in
well if you plugged it in and it didn't help try resetting forcing disk mode then restore again then plug it in
Posted on Mar 27, 2008
  • 13433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
Posted on Mar 28, 2008
I reset the my ipod just like the apple web site said. Then it showed a power cord going 2 an outlet from the wall. So i plugged it in the wall. It still showed it. Then I pressed the menu and center...
You must have a 3rd or 4th gen Ipod. It should not do this with a reset. If you reformat it through Itune , then it will. The plug into a power outlet means it is trying to reformat. If it will not, your hard drive is corupted or logic board. If it is the hard drive and you can get it to show on your computer, you can go to your disc utilities and erase the hard drive by writing zeros. then connect to Itunes and reformate. Plug into a power wall charger and it should complete. You need a good charge in your battery. If your battery is not charging or needs to charge , that will stop it from completing a reformat. I hope this helps.
Feb 07, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
It wont print
hey mr /ms
i hope i can be helpfull ..so plez tell me if the solution doesn t work ..and don t forget to rate me plez
Solution #1: Check the power cord at both ends. It might have been pulled out of the wall when you vacuumed last week, or the end that plugs into the printer might have come loose. If it did, plug it back in. If this is a new installation, make sure you didn't plug it into a power outlet that's connected to a wall switch. If the outlet is mounted upside down (the ground plug or "third prong" is at the top), it's a switched outlet.
Solution #2: It might be a blown fuse on the power supply. All dot matrix printers have fuses, and on most printers, the fuse is located next to the power cord under a small black cap that you turn slightly and then pull off. If it is the fuse (you'll see a melted piece of metal inside), replace it with the exact same fuse type. Radio Shack and your corner electron...
Aug 23, 2008 | Lexmark Office Equipment & Supplies
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
80 gig ipod
You need a new battery (iresq.com)
Mar 31, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod show plug in
This is the result of a firmware update.
You need to plug it into an Apple wall charger rather than a generic USB charger in order to complete the firmware update.
If you have used an Apple charger already then take your iPod to an Apple store as they can remedy this.
Mar 05, 2008 | Apple iPod MP3 Player
Ipod only shows outlet
Feb 23, 2008 | Apple iPod 4th Generation MP3 Player
Check out:
Apple iPod 4th Generation MP3 Player Logo
449 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
