Flame sputters I cleaned my beckett oil burner changed nozzle,filter, and set electrodes also changed screen in oil pump for the first time in 20 years [didn't know it was in there] now it starts up fine and runs good but flame goes out for a split second and fires up again this happens every few minutes during cycle checked ,air setting, tightened all oil line fittings still same problem. Any help would be appreciated Thanks
  • 43,501 Answers
Hey welcome to the world of oil burner service!! :-) Theyare a finnicky beast to say the least. The problem you are having sounds like an air mixture problem. A combustion analyser would be the best tool to have but being that you probably don't have that try this. On the left side of the burner as you are looking at it is an air adjust ment ring and a fine tuning ring. the fine tuning ring is probably all you need to adjust. There is a screw that is usually right behind or near the pipe coming out of the pump and going into the burner. Loosen that and turn the ring away from you just a bit to close off some of the air and you will be fine. The burner is running a bit to lean. If you can see the flame turn the adjustment closed just until the flame color turns from a almost white color to a slightly orange color. Then you should be fine. Good luck!!
Posted on Nov 15, 2009
Beckett burner starts and ignites but flame goes out slowly then get a lot of smoke why is this happening
It sounds like your filter is clogged. In the line from the oil tank to the burner there should be an in line filter. It is usually canister shaped and has a felt filter element inside. Shut valve off at the tank and loosen bolt on the top of the canister to remove bottom section of canister and access filter replace filter ( most hardware stores carry them) and reassemble canister. There is a small screw on top of the canister. Remove this to let air out when you open valve to let oil fill canister. When oil comes out shut off valve and reinstall screw. Reopen valve again and you should be ready for burner test. Setting a pan under the filter canister is a good idea to catch any oil from disassembling filter. Hope this Helps.
Bob
Oct 19, 2014 | Beckett B2502 Burner, Oil
Getting poor intermittent flame. I changed out my
It sounds like there is a leak in the suction side. Be sure all connections are tight and you replaced all gaskets etc. I am not familiar with your system but hopefully this helps.
Sep 30, 2013 | Suntec a1va-7112 pump,oil burner
Oil dripping from bottom of burner
Remove the electrodes & nozzle assy
Clean nozzle & check that it is tight
Sand electrodes clean,file ends flat
& set gap
Check the pump for leaks
Mar 02, 2013 | Cars & Trucks
My oil burner works fine while firing, but when it shuts off, there is fuel oil continuing to come from the nozzle. I get flames outside the combustion chamber when this happens, and I can find no...
The check valve is inside the nozzle. If you change your nozzle the problem will more than likely go away. Oil burners require annual routine mantainence to run properly. The part that bothers me is you said you are getting flames outside the combustion chamber. If the flame is outside the combustion chaber but still inside the furnace, you may very well have a broken heat exchanger which is very dangerous and could kill you with carbon-monoxide gas. I would suggest having this checked by a qualified HVAC contractor as soon as possible.
Jan 28, 2011 | Heating & Cooling
I think the fuel pump on my beckett burner is clogged is there a way to clean it. Ive replaced the filters and get fuel to the burner but get no fuel up to the line feeding the nozzle
As you face the burner, mounted in the unit, the oil line feed in on the left side. There is a cap, held on by 4 7/16" bolts. Inder the cap, there is a screen. You would be best to get a screen kit, available from the same place you get your nozzle, as it will come with a new gasket.
Shut off the oil. Remove the four bolts, pull the old screen, clean the housing (I use rags and WD40) and re-asssemble. If is is really bad, you should remove the nozzle assembley and flush the oil line to the nozzle, as well.
THe oil filter, screen and nozzle should be replaced at least once a year.
Jul 06, 2010 | Heating & Cooling
My oil heater stop working and won't switch on when I hit the reset button. Less than a month ago I changed the oil filter and a technician came and change the therostat flame detector on the oil burner...
How bad was the filter? Could be a plugged or dirty nozzle. There is a small filter on the back side of the nozzle that might need to be cleaned.
Turn off the power switch. Loosen and pivot the ignition transformer out of the way. Remove the tube with the ignition electrodes and the fuel tube and nozzle. Remove the nozzle, clean, and follow these steps in reverse.
Hope this helps, good luck, and work safe!
Mar 06, 2010 | Heating & Cooling
Beckett burner; I notice small particles of soot under stack vent
The soot can be caused by a number of reasons, if it was recently cleaned, I would wonder if the service tech just left a little mess behind. If you are reasonablely sure that is not the case, one cause could be a faulty pump. Inside the fuel pump is a pressure regulating valve, that is responisible for pump pressure and cut off. If the valve is failing, and not giving proper cut off, then a small amount of oil will drip into the chamber (called "after drip") and upon start up this oil burns incompletely causing a soot build up. A delay valve often masks the problem by providing the positive shut off electronically. Another problem/cause could be impoper adj. of the burner during the tune-up. On a final note, with equipment that old, it would be a good idea to start looking into a newer, more efficient system.
Apr 10, 2009 | Leviton White Decora Oil Burner Rocker...
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have...
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Aug 01, 2008 | Heating & Cooling
Heating & Cooling Logo
713 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
