Question about Siemens MC60
I have burn marks on the stove. How can I clean them off? My wife was bottling peaches, while boiling water some of the syrup would spill and the flames cooked in the syrup leaving bubbly stains as well as burn marks on my black stove, can they be removed?
  • Siemens Master
  • 8,404 Answers
Carefully try oven cleaner or a single edged razor blade.
I burned up a stove canning tomatos one summer ... file under "for what it is worth". Canned 50 gallons, yes, gallons, when I worked at the farm.
Good luck, I hope this helps ... what has this to do with the Cellular Phone category???
thanks for your interest in FixYa.com
please vote
thanks
a
Posted on Nov 15, 2009
How doe I freeze fresh peaches
Blanch them in boiling water 1 minute, then dunk in ice cold water to peel. Cut them up removing the pit, and lay out in a single layer on baking sheets. Place in freezer for a day, then transfer to freezer storage bags and store in the freezer.
Sep 11, 2014 | Home
How to freeze apricots
Before freezing, be sure you clean them thoroughly and avoid using any apricots that are damaged. Once apricots are washed and patted dry, cut them in half and remove the pits. Then slice them as you would slice peaches or any other similar fruit.
Boil a medium sized pot of water and dip the slices for about 30 seconds to prevent the skins from toughening, then place in strainer and run under cold water. From this point, freezing them may be done a few different ways, but the most important part is to be sure to include ascorbic acid to keep the apricots from turning brown.
One of the more common ways is to freeze them in a syrup. To make a simple syrup just add one cup of water with one cup of sugar to a pot. Heat and stir until all sugar dissolves. You will need about a half cup of syrup for each pint container you plan to fill with apricots. Then, add 1/8 teaspoon of the ascorbic acid to every cup of syrup.
Pour half of your syrup into a pint sized container you intend to freeze, then layer the apricot slices into the container, leaving about half an inch of space at the top, as the liquid will expand during the freezing process. After that, close the container, label it if preferred, and freeze it!
With this process, frozen apricots should keep for about 18 months if left in the freezer. Best of luck!
Jun 05, 2014 | Camping, Backpacking & Hiking
All 4 igniters are constantly on the only way to switch them off is at the mains.
This is usually caused by water getting to an igniter switch during cleaning, or from a boil over / spill. Disconnect power and let it dry out. It may take a few hours or a day, but should be fine after it has had a chance to dry out.
Dec 26, 2010 | Stoves 23 in. 600GRC Gas Cooktop
We just had it installed, Kitchen counter top, moss Green in color -Corian moving coffee pots with rubber feet leaves scuff marks , plates ceramic or china leaves scuff marks also , and they can not be...
Countertops
Cleaning All Finishes
Most dirt & residue
Use soapy water, ammonia based cleaner (not window cleaner), rinse and wipe completely dry. Commercially available solid surface cleaners, such as Clean EnCounters® will also work well.
Preventing hard water marks
Rinse and wipe completely dry after cleaning; clean up spills before they dry.
Removing hard water marks
Use a cleaner formulated for removing hard water marks such as CLR or Lime-A-Way.
Difficult residue
Spray residue with Deep Cleaner for DuPont Corian® from Stone Care International. Follow instructions on the bottle. Wash area with soapy water, rinse and wipe completely dry. If residue persists, follow steps below for removing dulling film.
Disinfecting
Occasionally, wipe surface with diluted household bleach (1 part water/1 part bleach). Rinse top thoroughly with water and wipe completely dry.
Preventing Heat Damage
While Corian® is heat resistant, as with all countertop materials, it is important to minimize direct heat exposure to protect your surface and investment.
DO NOT PLACE HOT POTS, PANS, ETC. DIRECTLY ON THE COUNTERTOP SURFACE.
Always use heat trivets or hot pads when placing hot objects on any surface. Always use a trivet under portable heat generating appliances such as a toaster oven. Allow cookware to cool before placing it into a Corian® sink. Preventing Other Damage
In most cases Corian® can be repaired if damaged. Be sure to follow these guidelines to help you prevent any permanent damage to your Corian®.
  • Avoid getting strong chemicals, such as paint removers, oven cleaners, etc., on your Corian® countertop. If a spill does occur, promptly flush the surface with water to fully rinse off the chemical.
  • Do not cut directly on Corian® countertops. Use a cutting board.
  • Boiling water alone will not damage your Corian® sink, however it is a recommended practice to run cold water from the faucet while pouring boiling water into the sink.
Removing fine scratches or a blotchy appearance
You may notice that the surface of your countertop begins to look blotchy. Typically, this is caused by leaving hard water to dry on the surface which will leave a film of minerals. To remove this film:
  • Pour some mild abrasive liquid cleanser, such as Soft Scrub®, on a damp sponge or cloth and rub over area using small circular motions, from the front to the back, then side to side, overlapping the circles until the entire area has been cleaned.
  • Thoroughly rinse the top with clean water and WIPE SURFACE COMPLETELY DRY.
  • Check to see if blotchiness is gone. If not, repeat procedure applying more pressure on the sponge or rag.
  • Continue over all affected areas until all film is removed.
Your new Corian® installation entitles you to certain quality assurance standards as provided in this Residential Limited Warranty. To obtain information and service under this warranty, contact the source from whom you purchased your DuPont™ Corian® installation or DuPont at www.Corian.com or call 1-800-426-7426.ifrcor_corianwarranty_10
Dec 21, 2009 | American Standard 7236.LBW.950 Glacier...
Gas was turned off and igniters keep clicking?
As I did not see what occurred, I suspect that the tea kettle boiled over and sent water into the burners. The igniters kept clicking and I eventually turned the gas back on. Will have to replace one igniter which apparently went out and have to light it manually at this point.
Dec 11, 2009 | KitchenAid Cooktops
I refilled the ink cartridge in my Lexmark x8350 all in one printer and the cartridge won't align. I've cleaned the cartridge repeatedly. What do I do next?
If white lines are present in the alignment page, then try this, warm some bottled water on the stove or microwave untill it almost boils. Then pour the water about a quarter of an inch deep in a plastic clean cup, place the printhead section of the cartridge, (the part that the ink sprays out of), in the water and let set for about 5 to 10 minutes. When you remove the cartridge from the water, dab it several times on a lint free paper towel or an old cotton cloth, DO NOT RUB or touch the printhead with your fingers or anything else. Then using a cotton swab dampened in rubbing alcohol, clean the shiney electrical contacts on the cartridge and where they touch in the machine. If you still cant align, then probably its time to replace the cartridge. You can only refill so many times before the printing elements burn out with usage.
Hope this helps,
Printdoctor
Dec 04, 2008 | Lexmark X8350 All-In-One InkJet Printer
Maytag gemini schott ceran stove top
Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
Jun 16, 2008 | Cooktops
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Cell Phones Logo
233 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Tre Elkins
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
