Question about Dishwashers
My fridge just stopped working this morning. Whenever I turn on the power the safety switch (fuse panel) trips off. How can I fix the problem by myself? I have cleaned up all the dust at the back and unloaded all the stuffs out.
  • Dishwashers Master
  • 43,501 Answers
I'm sorry but I think this is bad news for you. This is not something that you can fix yourself. The compressor is probably bad and is siezed up. This causes a high pull of power when is tries to start and cannot. This trips your breaker. Depending on the age of your refrigerator you may be better off buying a new than trying to fix this. Is it possibly under warranty still?? Get an estimate before you sink too much money into an older refrigerator.
Posted on Nov 15, 2009
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
I had a problem with our power this morning, the safety power switch kept turning off while I had a load on the washing machine. Now that the power is working properly, my washing machine is not working...
It could have been a developing fault in the washer which caused the safety power switch to trip and now it is permanently faulty.
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB, main motor, drain motor (my guess is the main motor)
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 11, 2011 | LG Washing Machines
My adp8540 has stopped working because my sister opened midcycle. Now it trips the circuit safety switch and if it does do anything else it blinks 6 times. Can it be fixed or do I jut need a new one?
Please remove off the main power supply and keep aside while pressing off the panel control. If the trip works, check if the motor is struck , release with manual action. Also check the motor, remove connection and see if the trip has changed. Also if there is any leak on the machine if the trip switch is a ELCB , which can trip with a ground/earth leak. If so check the outlet ground or use another plug point.
Apr 21, 2011 | Dishwashers
My fridge is tripping the power out in my house. do i need a new motor?
It might not be the motor, it could even be the door switch, but first unplug the fridge, disconnect the wires from the motor, insulate them, switch on and see if your house power trips out. If the house does not trip out it is the motor. It is still trips out, look at the wires to the switch and the light and also the thermostat. Good luck and remember to unplug the wall socket whenever checking any circuit.
Feb 13, 2011 | Whirlpool Refrigerators
Dishwashers Logo
195 people viewed this question
Top Dishwashers Experts
