Question about Philips J44414
Camera acting up
Worked fine for a while, now when I use it i see only black unless i point it at a light or computer screen, the you can see a little something. Everything else is black. Adjusting the lens doesn't do anything at all, not sure whats up.
  • Danae Jan 09, 2008
    im having the same problem my cam is also acting up... i get a black image... what's that all about? it work fine for a while but not anymore
  • bleed4me Jan 21, 2008
    Yeah the screen is all dark blue/purple like and I didn't do anything.It was fine at first,and I tried messing with the setting for a while to et it back to normal but nothing worked.I only got this a month ago too,gawd.
I just bought this webcam and it is doing the same thing... I think I'll have to return it!
Posted on Jan 13, 2008
Screen has gone black, all other operations work fine....
i would imagine that the screen has gone bad.sense you said it started to fade..screen replacement is very easy on the V3. There are 4 screws on the cover under little rubber pucks.Then gently pop the back off.and you'll see the camera and the ribbon cables ..undo them carefully, the rest is very self explaining.
May 12, 2010 | Motorola Mobility RAZR V3
While deleting pictures from y Kodak MD853, the
That is completely normal, as soon as you hook up usb cord, the camera screen will be blank. It will function just fine and normal.
Sep 23, 2009 | Kodak EasyShare C613 Digital Camera
On start up, screen turns white then black
I took the memory card and then turned it on and it worked. I put the memory card back in and everything works fine now. So just try that..
Feb 25, 2009 | Nokia 5310 Cellular Phone
Kodak Z1285 Won't Turn On?
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Jul 28, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Nikon s6 coolpix
I would check with Nikon and see if it's covered under warranty still. There could be something going on with the CCD unit
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Photo screen problems
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 09, 2007 | Canon PowerShot S1 IS Digital Camera
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Frozen in the boot zone
I just had the same problem and "fixed" it. I read the other solutions and while the camera was on I gently inserted a tiny probe in the hole on the front of the camera, then [camera is still on] I reset the camera with the same probe on the reset hole in the back of the camera.
This fixed the problem immediately. I know the questions were years ago but there is no Concord site now and I thought I would help.
My theory on how the camera got that way is that I might of had my finger over the lens while powering up and prevented it from coming out - maybe there is a "trip" switch to keep the little motor from burning up in that situation and you reset the switch thru the front hole? Anyway that worked for me and kept my [for years] great little camera, with lousy instructions on use, working.
Thanks to whoever runs this website saved me money $$$$$$!!!!!!
Oct 08, 2006 | Concord Camera 3346z Digital Camera
Black screen picks up only bright lights
if it is only recording bright light sources then it must be working fine outdoors in broad day light. if so, it means the auto iris of your camera has stucked to minimum opening. was the camera lying idle for long time. try pointing the camera towards low light and bright light with quick moves.some times by doing so it gives a little jerk to the mechanism and it starts working, or lightly patting the camera on the lense side may solve the problem. otherwise let the repaires earn some money.
Oct 08, 2006 | Quasar VM-L152 Camcorder
Black LCD screen on camera
Just had the same problem (black display). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Aug 30, 2005 | Pentax Optio 330GS Digital Camera
Philips J44414 Logo
21 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
