Question about InFocus X1a DLP Projector
I have the same problem as someone else has posted on this site. When I start up the projector, x1a, it goes directly to a faint white screen without any button response. With or without a video source plugged in it shuts down the lamp automatically. I've been looking for awhile and I cant find which part of the projector is causing the problem.
  • 2,236 Answers
Replace the colorwheel. part # 525-0144-00. you can get it through av solutions in ny. www.avsolutionsny.com it's not that difficult to replace, but if you are unsure about it, you can send it it to them to repair as well. they are an infocus service center.
Posted on Dec 03, 2009
I have a 46 inch LCD LN46A630. It was working fine and suddenly the screen when white. You can faintly see a picture beneath the white screen. I spoke with someone from Samsung that directed me to
It sounds that its main digital board has damaged. Video processor section has the fault. It has no repair at component level. Should be replaced as card basis. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Pull up older posts there.
Oct 15, 2012 | Samsung LN46A630 LCD TV
My wife turned on our X1a and the whole thing died. She said she heard about half the normal "beep" before it completely shut down -- no LEDs, no fan, nothing. (I'm currently away with the military and...
the most inexpensive thing to change would be the power input board, which is what the plug plugs into, if that isn't the problem, you can look at the glass fuse on the power supply next to the input board to see if it is blown. if it is the fuse then the power supply needs to be replaced unless you know someone to desolder and resolder a thru hole fuse. Also, make sure the lamp door is shut properly. If the door doesn't push the safety switch in it will not complete the cicuit to allow power to the projector.
Jun 13, 2010 | InFocus X1A Multimedia Projector
My projector has a white flashing line on the left side of the screen
you can try cleaning the connection from the main board to the back of the lens assy, if that doesn't work you will likely need a new main board or a dmd board for the lens assy.
Feb 24, 2010 | InFocus X1a DLP Projector
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
Infocus x1a projector shuts down after 30 seconds - dust problem ??
do you have the correct lamp? the x1a takes an sp-lamp-009, that has 2 white wires, and not the more common sp-lamp-018 which looks exactly the same except has one white and one red wire (and are in different plug positions). if it still doesn't light, there is another issue (possibly the colorwheel) along with the lamp timer reset.
Mar 18, 2009 | InFocus X1 Multimedia Projector
Samsung LCD suffering from faint white lines scrolling, and buzz
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 22, 2017 | Samsung LN-S3251D 32 in. LCD HDTV
Infocus x1a fan replacement
Hi there
I just sent you an email through fixya and I don't know if it went through but I was just saying about the fan and the grey bar. The problem with the fan, is not the fan itself, but the controller board not supplying enough voltage to the fan (you can see this by powering the fan on its own using a 6volt supply, you will fine that the fan will work perfectly normal), thus having to replace the entire control board at around $650+, this is a very common fault for these models. The grey bar as meantioned in my post is caused by the faulty light tunnel, there is a link I've posted here somewhere which tells you how to fix it, but you need extremely strong glue and electronics skills lol, otherwise infocus wouldn't sell me the part on its own, only the whole optical enigne at another $450+. Very poor service in regards to infocus.
Cheers
Rusteee
Apr 03, 2008 | InFocus X1A DLP Slide Projector
No picture, no buttons work
unplug for a day and try plugging it
Dec 10, 2007 | InFocus X1A DLP Slide Projector
X1a powers on, then video dies
Check whether the menu comes on the Screen. then check the DMD circuit.
Jun 04, 2007 | InFocus X1A Multimedia Projector
InFocus X1a DLP Projector Logo
172 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
