Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Rawbreys money pit
Like i said in my other post the red light comes on when plugged into outlet and when you hit power button it flashes orange 2 times about 5 seconds apart the manual i looked up said there was a problem with the lamp cover and to resecure it ive put it in place secure and its hooked up to the 2 prongs in the lamp slot but still flashes orange any help would be cool . unless your like the idiot who gave me that last dumb bit of advice. My advice for you asshole 1 is pull your head outta your asshole
    Problem Solver:
  • 3 Answers
Re: rawbreys money pit
I had a similar problem. I kept re-seating the bulb unit (3 attempts) and the error finally went away. I figure the contacts were dirty and the constant of re-inserting the bulb may have cleaned the contacts. Hope this helps.
Posted on Jan 10, 2008
0 characters
3 Points
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
While I am watching TV on my Sony kdf-60xs955, the screen goes blank and the green light just flashes. Sometimes it comes back on and sometimes not. I hit the power button and the red light flashes 5...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Check by changing the Power cable to any other wall outlet in your home
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Apr 03, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Aug 27, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Won't turn on
Can u tell me model no and brand name so that i can help u sir..
Sep 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Thomson dti 6300 freeview box will not come on just shows constant red/orange light flashing all the time, tried leaving power off etc....anyone know?
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Apr 13, 2008 | Projection Televisions
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
