Question about D-Link Vonage-enabled Wireless Router (VWR-VR)
Does not save wireless security settings
Wireless Linksys Dlink VWR router - does not save wireless security settings. Please help.
  • 72 Answers
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
Posted on Jan 05, 2010
How to change pin of dlink router permanently?
go to wireless security settings of the router and do it u will be able to change the pin
Mar 13, 2014 | D-Link Vonage-enabled Wireless Router...
Hi, how to create a password for my network, i;m using a mac kind regards
This is done by navigating your browser to the router and logging in. I suggest that you go to dlink.com and download the manual. Access is similar to 192.168.0.1 in the ADDRESS BAR, not search...
Here are the highlights of what needs to be set.
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Jan 14, 2011 | D-Link Vonage-enabled Wireless Router...
Lost my wireless connection on linksys wireless g wrt54g v.4 router help.... called linksys wants to charge 39.99 for a quick fix plz help
My friend,
Please reset the router by pressing the reset button for at least thirty seconds.
Open the setup page of the router with 192.168.1.1 from Internet Explorer.
Username=leave this blank.
Password=admin
Router setup page will be displayed then.
Click on the basic wireless settings .
Give the network name(your choice) and channel =6.
Under wireless security settings .
Click on the security mode should be WPA.
Put a security key.
Save settings.
It will start working wireless .
Saved your 39.99 $
Regards:-
Amit Awasthi
Dec 12, 2010 | Linksys Wireless-G WRT54G Router
How to generate a network key for Dlink Wifi Broadband?
The encryption key is set up in the router's wireless settings.
For these details and to secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 08, 2010 | Linksys Wireless-G Broadband Router
How do i change my password. Guy downstairs is using it and downloading movies.
log into router by typing 192.168.1.1 on the address line of Browser
Username blank
password admin
go to wireless settings and change the WPA key use an old phone number you can recall from memory
Save settings (If you are connected wireless, you'll be kicked off till you log in with the new WPA key)
Mar 26, 2010 | Linksys Wireless-G Broadband Router
Low signal strength
Having many users connected to a single WAP (wireless access point) will not affect the signal strength. It will however, affect the speeds each user is capable of.
Most Linksys routers have a homepage address of 192.168.1.1 - Enter this in your web browser.
From there you will be able to find wireless settings and enable either a password or a WEP key for security.
If you found this helpful please leave feedback.
Feb 05, 2010 | Linksys Wireless-G WRT54G Router
I hooked up my DLink VWR and cannot get internet connectivity
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 28, 2009 | D-Link Vonage-enabled Wireless Router...
I need to set a passowrd for my wireless router.
The default username and password is "user". For the security settings, you need to setup WEP/WPA-PSK etc. Steps are outlined in the manual.
Link to the manual:
http://www.abadss.com/forum/attachments/1037-router-users-manual/19159d1248742164-user-manual-d-link-vonage-model-vwr-vd-router-vwr_userguide-1-.pdf
Sep 10, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
How do I secure my dlink wireless connection?
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
968 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
