Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
My pt53wx53g screen just went black I unpluged it and pluged it back in. It is flashing 3 times and pausing on the power on light and then repeating
  • Jeff Fortie Nov 15, 2009
    would you please send me your step by step repair for my Panasonic PT-53WX53 and also where is this best place to get the chips I need Thank you
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Three blinks is short protection----95% of the time in this set it means one of the two STK-392-110 convergence chips is shorted.
If you unplug the set and remove the back cover:
Look inside for the two chips: black in color--2 1/2 inches wide X 1 1/2 inches tall with the STK printed on them in white.
The will be on metal heat sinks with fins side by side.
What you are looking for is there are about 10 or 12 light blue resistors around them---most are marked 2.2 ohms---if you find even one of them discolored or somewhat white in the middle----YOU have found and confirmed your problem.
Parts cost if you can do it yourself is under 30 dollars--if you or someone you know can do it you can save the set and a lot of money--most shops get 300 or more for this type of repair.
I can also tell you the best place to buy the chips.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET; IF YOU WANT THEM I CAN POST THEM HERE.
Repair involves getting at the chips and being able to unsolder them--the instructions are my own and tell you everything you will need to do the repair.
I have repaired hundreds of these sets with this problem.
If this information has helped rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
Testimonial: "Thank you! this helped a lot and I would love it if you would tell me the best place to find the parts I will need and send me your step by step instr"
  • SD Tech
    SD Tech Nov 15, 2009
    I will post this first and then the instructions here.
    On Ebay, select search, then advanced search, then search by seller: sewsales55 this is a company I buy from called Suburban Electronics in Maryland---they will also have some of the other items in the instructions that you will need.
    I am posting this now and in a minute I will post the instructions.
    SD TECH
  • SD Tech
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    PANASONIC CONVERGENCE IC REPLACEMENT:
    What you will need;
    Two new STK-392-110 convergence Ic’s
    Solder
    Liquid solder flux
    Desoldering braid or wick
    A good soldering Iron
    Some denatured alcohol
    A small toothbrush
    A Philips screwdriver or screw gun to REMOVE SCREWS
    A PAIR OF GLOVES
    1. UNPLUG
      TV SET.
    2. Remove
      back cover of TV set.
    3. Remove
      entire front speaker grill on set(it pulls off and may resist being
      removed)
    4. Locate
      and unplug speaker wires (they are plugged into the main circuit board).
    5. Locate
      three cables with wires that come from the Front keyboard—two of them have
      to be unplugged from the main board(all plugs are different sizes but note
      where they go)
    6. Remove
      2 long philips silver machine bolts from the front of the set (behind the
      grill).
    7. Remove
      4 more in the back of the set; two
      are located at the extreme back edge of the plastic frame and hold the
      chassis down; two more are located on either side and also go straight
      down; note which are which and set them aside.
    8. Using
      gloves pull the entire metal box (it is called a light box) out of the
      set; there are hand holds on either side—careful as the metal has sharp
      edges.
    9. Remove
      the box from the set and locate the two Convergence IC chips; they are
      located on identical metal heat sinks with fins and they should have the
      STK-392-110 number clearly printed on them in white (they are black)
    10. Turn
      the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is
      a good idea to apply liquid solder flux to the pins on both chips now. I recommend using a de-soldering braid
      for this—get all the pins completely de-soldered.
    11. Inspect
      the dozen or so light blue resistors in front of them; most are marked 2.2
      ohms—if any are white in the middle you will need to replace them at the
      same time; best way is to check all of them like checking a fuse----they
      protect the set if one of the STK’s shorts in any way.
    12. With
      the STK’s completely unsoldered turn the box upright and remove the two
      screws on each IC. If the chips
      have never been replaced you will need to tap them loose with a putty
      knife or flat bladed screwdriver.
    13. Remove
      both IC’s.
    14. Apply
      heat sink grease to the two new IC’s and install them one at a time; this
      part can take some time and it is important the pins on the new IC’s are
      perfectly straight---once you get them in, Hand tighten both the screws on
      each IC---do not use a screw gun—you can strip the screw holes out. Clean the bottom of the circuit board
      where the chips were soldered with some denatured alcohol and apply liquid
      solder flux to all the pins.
    15. Presuming
      you have already found/replaced any bad resistors turn the box back over
      and solder carefully both of the two new IC’s in, --do not short any of
      the pins to each other when you do this and when you are done it is a good
      idea to take a close look at both to make sure all pins are soldered and
      not touching each other with soldering you have just done. I suggest you
      do clean the pins on the bottom of the circuit board again with denatured alcohol.
    16. Slide
      entire light box back into the cabinet.
    17. Reconnect
      the plugs you removed when you removed the box. At this point take a lens
      cloth or a paper towel with glass cleaner sprayed on it and clean the
      three large black lens-if they are dusty the picture will be darker and not
      as clear as is should.
    18. Position
      the box so it is all the way in place and none of the wires or plugs are
      pinched.
    19. I
      usually at this point turn the set on before I replace the Six bolts that
      hold it in—2 from the front and the four in back----this way if you have a
      problem you can remove the box faster.
    20. If the
      set comes on and now has normal Convergence go into the customer menu and
      adjust the convergence in the multi-point mode----CAREFUL! THE FIRST
      OPTION this set usually offers is a
      green cross in the middle of the screen—do not adjust Green!
    21. Once
      you have the Red and Blue in the center adjusted find the second
      convergence mode---it will give you 8 or nine points on the screen with
      instructions on how to change from blue to red---use the original remote
      with the thumb wheel or cursor buttons to adjust.
    22. NOTE:
      SOME of these sets need to have the Convergence adjusted in first:
      full/4:3 and second in the other two zoom/wide zoom and third on the HD
      input with a HD signal coming in.
      There is also an option at this point to go into the Technical menu
      and fine adjust the convergence all over the screen—if you need this I can
      give you instructions based on the model you have—most of the time
      adjusting the set in the customer mode will produce a good result.
    23. I know
      all this may seem complicated to you, but this repair should take about an
      hour or so and just take your time when you get to adjusting the set.
    24. If all
      looks good turn the set off and Unplug it; install all 6 of the chassis
      bolts back; replace the back cover and the Speaker grill and plug the set
      back in.
    25. You
      may find it useful to go over the convergence Adjust again—to get all the
      points as good as you can. There is
      a hidden Tech menu that will allow a finer adjustment of the entire
      screen----it is somewhat difficult to access and there are a lot of
      buttons on the remote that then do different things.
    26. Most
      of the time adjusting in the customer menu will give you a very acceptable
      picture.
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Sony High Definition Projection TV Standby light flashing nine times, tv will not come on.
you could have a bad lamp i have seen new ones do the same thing if not you may have a bad power supply
Jan 29, 2009 | Sony KDS-60A2000 60" HDTV
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
265 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
