Question about Sony Audio Players & Recorders
Sony CFD-454 CD Player will start to spin CDs but will not load
CD Player will start to spin CDs but will not load the track number and total time; and will not play when the ''Play'' button is pressed.
Benimur
  • 6966 Answers
SOURCE: TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Posted on Aug 04, 2007
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: i cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Posted on May 19, 2009
  • 4234 Answers
SOURCE: My Sony cd player spins but won't play. Cleaned
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Posted on Jun 15, 2009
SOURCE: NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Posted on Oct 06, 2009
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
No sound from cd player
the laser lens needs cleaned most likely, you can purchace a cleaning disk, or take the unit apart and used a eyeglasses cloth and very gently wipe the lens clean. the lens will be very small and near the motor that spins the cd. when wiping it off, wipe in one direction only. if that doesnt work then the laser has become weak or has quit working
Jan 14, 2010 | Sony CFD-E75 Cassette/CD Boombox
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto www.sony.com for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
May 22, 2007 | Sony CFD-S300 Radio/Cassette/CD Boombox
131 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
