Question about Sewing Machines
I have a homemaker everyday overlocker sewing machine. I have threaded it and re-threaded it for both three and four threads but can't get it to work. The stitches do not take - or knot - or whatever it is. It appears the needles are slightly off timed, although I know nothing about the mechanics of sewing machines but the threads from the underside do not catch the loops of the needles. Does this make sense? Is there anything I can do?
  • dickiedavey Nov 16, 2009
    Thank you - I suspected as much, but hoped it was simple.
    Brigadier General:
  • 4,044 Answers
Not that you can do. Double check the bobbins to ensure that are properly installed. If they are then you will need to take this to a shop to have it repaired. It sounds like a gear slipped.
Posted on Nov 15, 2009
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
Hi. About 5 years ago I purchased a Janome 744D Overlocker which I have only used once because the thread on the underside keeps snapping, and the needles keep breaking off. The foot is also very touchy...
Yes, overlockers sew fast, usually 1500 stitches per minute and with a blade in action alongside the loopers so there is a lot happening. Keep all pins well away from the seam edge, contrary to normal sewing machine techniques, if you pin two layers together, then place the pins parallel to the fabric cut edge at least 2 inches away from the edge so the pin goes nowhere near the foot or blade.
Check whenever you use it, that you firstly extend the thread aerial up to full height, you need to ensure the threads can flow smoothly to the tension dials as the thread will stream off fast, even the slightest catch of a thread will snap one, throw your tension out or damage a looper.
As you've had it all this time and not used it, why not consider investing a few dollars more and go to a class on overlockers, and learn how to thread it up for three, four, rolled hem and using the differential feed. If there is no class options in your area, then try the Janome dealer near you and see if they would consider giving you a a little lesson on using it. You could also check out the videos on You-tube or read some pages from Debbie on www.sewing.about.com, she has several pages on sergers (USA name for overlockers), explains the needles, threading, different techniques and maintenance. Or check out your local library for any books on sergers/overlockers, there are several good "how to" guides out there that would certainly help you get started.
Unfortunately there is no way to slow the speed to half speed, just practice with lots of fabric scraps at first, to get used to the sensitivity of the foot control. If you do dressmaking but aren't sure where to overlock or which seams you could only overlock, then consider just doing a three thread overlock around the edge of each fabric piece before you commence assembling the garment, just do your notch markings another way such as chalking them or using water soluable marker pen as the blade will cut away your outwards notches.
My other suggestion would be to make a simple sweat shirt on it using the 4 thread stitch and not touching your sewing machine at all. Once you've made one, you'll soon be wizzing them up in 30 mins, so quick to sew knits on an overlocker. Some of the commercial patterns are marked as suitable for sergers, look for one of these to try.
I hope this helps you to master your overlocker, a lesson or class would help you with the steep learning curve at first.
May 22, 2011 | Janome Sewing Machines
I bought a silvercrest overlocker and I am not able to thread one of the threads it has four threads
Kindly confirm the model number? Do you have an instruction book for the same?
Thanks!!
Jun 29, 2010 | Brother 1034D Mechanical Sewing Machine
Problem with Homemaker overlocker
first thing to do is lodge a complaint
and send all emails via ebay so it is recorded,
if you paid via pay pal you may have some kind of guarantee. over lockers can be very sensitive and may require some thing as simple as adjustment or lubrication or at worst a service.
threads breaking are caused buy poor thread quality or over tension,or wrongly threaded.
Over tension can be caused by the the tension guides being rusty or stuck. pull the thread through the tension guides to see if it is moving with some minor friction. hope this helps
May 04, 2009 | Sewing Machines
Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
Jan 12, 2008 | Sewing Machines
Janome Overlocker
Is it a three or four thread machine?
A three thread has little strength used as a seam.
On a four thread,basically, it is a tension problem. You need to ensure that the presser foot is in the up position before threading. The correct path is followed for all threads. You are using good quality thread. Reset the dials to 'normal tension' #3 or 4 .... then slowly work your way from there. The manual should offer advice on which tension to adjust to correct a particular problem.
Oct 08, 2007 | Singer 5160 Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
