Question about Sony Playstation 3 (PS3) Console
Disk player doesn't work - Sony Playstation 3 (PS3) Console
    Problem Solver:
  • 5 Answers
Your HDMI receiver probably cannot handle multichannel PCM or your HDMI receiver may not be HDCP- compliant.
Posted on Nov 15, 2009
Carousel doesn't work
Try re-timing the mechanism. It is probably a tooth out.
Jul 11, 2017 | Denon DVM-1800 DVD Player
Dvd keeps on scanning disk
If it's only one DVD that has this problem then bring the disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it does this for every DVD then clean the DVD player with a laser lens cleaning kit. If that doesn't fix it then the player will need to be replaced.
Aug 19, 2012 | Televison & Video
Dvd/cd rom can't read dvd
Sometimes you just need to clean the disk or the dvd head on your player. If this doesn't work the disk is of the incorrect format.
Jul 29, 2012 | HP Computers & Internet
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
Dvd player can't play blue ray disk
If you have an earlier model Compaq, it most likely a DVD ROM player. Check the printing on the drive tray, if it says DVD ROM then it cannot play Blu ray disks.
Aug 19, 2010 | Compaq Presario Notebook
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
The player does not recognize the hard disk after converting to NTFS.
check and see if the harddrive settings are set to master. this will solve the problem
Nov 07, 2006 | Lasonic HV-670
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
