You will need to take the cover off of the breaker panel. Find the three lugs that the incoming hot wires are hooked to. With three phase you will have three hot lines. Check the voltage between the phases. L1 - L2- L2- L3- and L1 - L3 Also check the voltage from each line to ground. If you havw 120/208 three phase current you will have 208 +or- a few voltage between the phases and 120 or so from each line to ground. If you have 120/240 three phase you will have 240v across the phases and 120 to ground on two legs and 208 to ground on one leg, this is called a "wild" or high leg. You may also have 480v into the shop and you will know that very quickily if you get 480v between phases. No matter if you have another voltage, you can buy a trandformer that can convert whatever you have to 208/120 3 phase for your unit.
Testimonial: "Very quick response and found out just exactly what I needed"
