This problem should be removed because:
Problem with Vizio VO32L 32 in. LCD TV
My vizio VO32L will not respond after being tuned to 5.1 in Los Angeles. I have two other analog tvs with converter boxes that work fine on channel 5.1. My newer vizio VL320M will go blank when
tuned to channel 5.1 and return to another channel.
Solutions (1)
I'm having the same problem (in the LA area too!) with my VO42L and VO22L...I called Costco and they've handed me over to Vizio. I'm waiting for a call back from Vizio right now, but I told them about your post. Hopefully, they'll get flooded with calls!
remote Control Code
what is the romote code for model # vizio VO32L HDTV 10A?
My Vizio turns itself off on a certain channel (ch...
I re-scan the channel for few times and the problem still there. Whenever I turn to channel 17-1, my Vizio turns itsel off. Any advice?
vizio 320m. I set it up wrong. Instead of choosing
vizio vl320m. I set it up wrong. Instead of choosing a different source such as my cable box during the initial setup I chose cable. Now i...
VL320M no picture just a black screen. sound no
VL320M no picture just a black screen. sound no picture
Add Your Solution
NO SOUND
JUST LOST SOUND DON'T KNOW WHY
i Have a vizio v032l 10a fhdtv. turns on fine and...
eventually it wont turn back on untill you unplug it and wait a minute then it will but is just a never ending cycle....
The white areas of my TV looked pink. Then thw
The white areas of my TV looked pink. Then thw whole screen became green and blue. Still has a picture (with wrong...
Black screen , was watcing
Black screen , was watcing tv and the screen went black , still has sound and can change channels , tried unpluging and...
Fix-O-Meter
124
124 people viewed this problem
- 0 people are following this problem. Be the first!
Top Vizio Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Update: They say it is the broadcast, but I said my DVD recorder (and your two analog with converter boxes) work fine,. So it has to be a disconnect between 5-1 and Vizio...not
just 5-1. So, I'm waiting back for another call. I'm also going to send an email to KTLA and tell them I am a
faithful watcher of KTLA morning news, but I can't watch unless they
work with Vizio to fix this problem. Hopefully, both KTLA and Vizio
get flooded with calls and resolve this.
