Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
661fx-m7, It is running ok for 6-10 minutes then pc shuts down with no warning. this can be when it is active or just sitting idle. any ideas please?
  • crie Dec 02, 2009
    Thanks to all, it was an overheating problem which I countered by installing a case fan blowing directly onto the heat sink of the CPU. As the CPU fan was blowing directly onto the memory sticks I also installed a baffle which diverted the hot air away. One or both of the solutions has solved the problem and there has been no further shutdowns. Thanks to all for the advise and help.
    Problem Solver:
  • 10 Answers
This is generally an indication of a processor error. It may be running too hot and stops working when it overheats.
Posted on Nov 15, 2009
    Scholar:
  • 124 Answers
Try This At Boot Hit Delete Key And Enter Bios Go to advanced settings hardware monitor Monitor how hot the cpu is running if the computer stays on in bios mode but will not run windows you may need to upgrade bios and windows hardware drivers This could allso be, ram related hard drive, or power supply. but it sounds like cooling problem. The hardware monitor in bios will help you narrow it down
Best Of Luck With It
  • 535 Answers
Is this happen due to dust on your processor fan due to dust your processor heat so much that y its off in 5 to 10 min so clean the processor fan by the blow air or by the brush
Driver sound card
Hello. You can download the sound card driver for your EliteGroup 661FX-M7 Motherboard by accesing this website: http://driverscollection.com/?file_cid=42171620436b85b5f3172dd905e
The driver above is available for the following operating systems:
Windows XP
Windows XP 64-bit
Windows 2000
Windows ME
Windows 98
Enter the code shown then download the driver to your computer. Run the program and install it properly!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
May 28, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
Does a core 2 duo processor work on an ecs 661FX-M7 motherboard?
Your motherboard was set up for a pentium 4 or celeron d only and neither are dual cores, So the short answer is no,'
But there are many 3+ ghz celeron d's that are less then 50 online
Oct 06, 2010 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
Where to i download manuels for motherboard 661fx-m7
http://www.driver-central.com/661FX-M7_BIOS-8735-e7b0-driver.html
May 15, 2010 | EliteGroup 661FX-M7 (661FXM7V11)...
Im looking for all drivers for mercury kobian 740 ecs?
here it is...
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=0
select motherboard in the 1st drop down
select lga 775 in the next drop down
select 661fx-m7
select ver number in the next drop down
click submit
and there we go
please rate the service you have recieved
Apr 24, 2009 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
661FX-M7 Problems
The fan running at 100% may be fine, depending on how you hooked it up. However, you seem to have a conflict with the video. The short beep you hear is usually the motherboard recognizing the boot drive. The long beep means something isn't configured correctly possibly the video card...?
Look in the owners manual for the keystroke to get into the bios settings. Then right when you turn it on, before the long beep, hit that keystroke and get into the bios and check settings.
NOTE: if you don't get any video when you enter the bios, there is clearly a compatibility issue with your video. All video cards should put out signal for the bios - even if the proper drivers aren't loaded for Windows.
Nov 03, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Where could i find BIOS Jumper for mother elitegroup 661fx-m7?
Hi MATTOTECH, when you receive a reply from a tech or wish to continue the post with the same tech do this. When you log into Fixya go to you're profile, listed there will be you're question. Open that question & continue / post more question (s). When you create another question like above, you will not get the same tech.
MATTOTECH if you do not have you're user manual for the ECS 661FX-M7 (V1.1) motherboard. You can download it from this link. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=476&DetailName=Manual&MenuID=44&LanID=0
Create a folder on you're desktop & give it a name. Download the manual, file name 661FX-M7.zip into the folder. Uncompress the file within the same folder. You will need Adobe PDF reader to view the pdf manual. If you do not have Adobe reader you can download it for free here. http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Go to page 4 which will show you a picture of the board. Each item is numbered. Page 5 will describe each number.
Number 6 is the bios jumper. Than go to page 9. This will show you how to set the jumper to clear the bios/cmos. (Leave it in the clear position for 15 seconds), than move the jumper back to pins 2 & 3, its normal position.
EliteGroup 661FX-M7 (V1.1) main web site
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=476&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Mike
Jul 25, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Computer starting up and the processor turning too fast then the pc shot down by self
Are you hearing any beeping sounds and also please check your power supply by removing the supply 20-24 pin cable and refresh the bios - see the bios jumper is inserted in normal position
Thanks Hothawk
Jul 24, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Driver
Is this right? ACS 661FX-M REV:1.0 or this ECS 661FX-M7 v. 1.1
If ECS 661FX-M7 v. 1.1 you can downloads it here : http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=9
Dec 10, 2007 | Computers & Internet
At witts end
Give the vents round the side and underneath a hoover out first, then check in acer e manager, there you should see settings for your fan, HDD and hibernation , you can set the fan on all the time or default, check it's set correctly and see if you resolve the issue. Turn hibernation off and HDD idle shutdown off to see if any change in shutdown. Does the pc shut down in any particular programme?
Jan 15, 2007 | Acer Aspire Notebook PC
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
295 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
