Question about Zebra TLP 2844-Z Thermal Label Printer
After calibration the first print is fine.. 2nd print to label seems to backup into the printer before the next print ..result in text missing info... workaround is ..I need to pull the label out a little bit..so when it backs up... it prints fine.. I dont want to do this everytime and I dont want to calibarte every time...what am I missing in the setting label size setting 4x4
    Scholar:
  • 62 Answers
Sounds like you are printing from Zebra Designer, if so all you need to do is click File/Printer settings/Advanced setup/tick the box marked "Top of Form Backup" OK, and then save your label file.
Posted on Nov 20, 2009
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
CALIBRATING THE TRANSMITANCE FEED GAP SENSOR DOESN'T SEEM TO BE WORKING. FOLLOWING THE RECOMMENDED PAUSE, SELECTION OF METHOD (TRANSMITANCE) AND FEEDING MORE THAN 3 LABELS GIVES OFF-CENTER PRINTING AND...
im not familiar with the toshiba printers but i know most others have a way to calibrate using just the paper first and then the label. do you have a manual for it?? if not try and download it from toshiba. are you using a new label supplier? maybe the opacity of the liner is a lot higher on the new stuff?? setting is for sure set on gap??
Aug 06, 2017 | Toshiba TEC B-SX4 Thermal Label Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
May 13, 2008 | Zebra 105SL Thermal Label Printer
White space between labels
OK, guys, I spent some time with this, and you have to do this:
If you use ZebraDesinger, go to File-Printer settings-Advanced Setup-Calibrate
The printer will need approx. 40cm of the paper (labels) to calibrate where is the begining.
After that it was working good.
Just make sure, you have input correct With and Heigh of the label.
How to do that?
-get into Label setup wizard
-choose the printer -> click on NEXT
-choose stock type and stock name (I have ALL and <NONE>) -> click on NEXT
-set Height (count with space between labels, so measure from the start of the label, till start of another and Width. -> click on NEXT
-set other settings -> click on NEXT
-set width and heigh (this time without space between labels)-> click on NEXT
-Finish
then calibrate the printer and enjoy your work.
Apr 22, 2008 | Zebra 110XiIIIplus Direct Thermal/Thermal...
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
290 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
