Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Put new moen cartridge in and I have no water at all coming out of the faucet
  • 119 Answers
Do you have cold coming out? was this the problem that caused you to change cartridge? Did you use a Moen brand cartridge? if yes then the problem is in the balancing spool which is located on the left side of the valve it is a round brass fitting with a slotted head you can remove spool while water is off and clean debris from spool make sure you hear a clicking noise while shaking the spool if not lightly tap it on a hard surface until you hear a clicking noise or if you used an aftermarket cartridge like Danco brand return it and call moen for a free replacement
Posted on Nov 15, 2009
5 Suggested Answers
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 349 Answers
SOURCE: Moen kitchen sink faucet side sprayer is stuck on
The diverter valve in the faucet may be stuck or bad. This web site has some views of faucet internal parts. Hope this is helpful to you.
http://www.faucetdepot.com/prod/Moen-136102-Replacement-Hydrolock-(R)-Connection-27981.asp
Posted on May 29, 2010
SOURCE: Loose handle on my Moen single handle kitchen faucet
I had a similar problem. After a few weeks the lever began to "tighten up". It began first with the hot water at full flow and progressed over a couple of weeks to full control.
Posted on Oct 28, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen kitchen faucet
    Hi Steve-If the faucet is definitely getting water (making sure all the cut-off valves are open along the way), the Moen single handle faucets all use a replaceable cartridge that is available at home supply stores. This cartridge is what regulates the pressure and the temperature of the water coming out of your faucet. This is likely faulty. You'll need to close the supply valves (hot and cold) underneath your sink prior to replacing.
    Apr 01, 2014 | Plumbing
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
    shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
    Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen T2301 tub faucet
    you may have deposit's,(mineral) in water way's. maybe piece of cartridge came off and blocking water. try removing cart' and inspect brass valve body,to see if any thing is there. check cartridge as well.
    Apr 22, 2010 | Moen & One Handle Tub & Shower Faucet
    The moen began to leak over time now i cant turn the water for
    Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
    Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    0n a Moen TL2383--what do i do to get hot water thru only cold comes out
    The tl2383 is just a trim kit...if you have a 2 handle shower valve and it is moen then the number is 2919....you just need a new cartridge if you are not getting any hot water....it is a 1224 cartridge.
    Oct 09, 2009 | Moen 2919 Chateau Two Handle Tub and...
    Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
    603 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
