Question about Baby Gear
The plastic piece that's used to raise & lower the side rail is missing. I need to find some way to fix this for my nephew & his wife. Please help!!
  • 340 Answers
You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs.
Posted on Nov 18, 2009
ICE FORM AT THE BOTTOM OF THE FREEZER ALL THE TIME, LEAKS OUT ONTO MY HARDWOOD FLOORS AND FORM PUDDLES
Step 1: . Unplug the fridge. You can wait until later but don't forget.
Step 2: Freezer door. It's 4 screws, one in each corner. Just loosen them a few turns - don't take the screws out entirely - it's much easier putting the door back on when the screws are already in place. The door slides up & off.
Step 3: Lower basket. It lifts out, no tools required. Now's a good time to start eating all your ice cream.
Step 4: Upper basket. Remove the 2 screws at the front of the rails, then lift up the rails slightly on each side, to slide the basket forward.
On the plastic pieces at the back sides of the upper basket, push in two tabs with your screwdriver on each piece & pop them up. This will let the upper basket slide out off the rails.
Step 5: Icemaker. Remove the lower screw, then loosen or remove the two screws above the icemaker. Unplug the wire harness where it passes through the rear panel - squeeze the sides of the plug & pull. Lift the icemaker up & out. The water tube will slide out of the guide.
Step 6: Plastic guards.The thermostat guard is the skinny piece to the upper right. Push in (to the right) the tab on the left side in the middle. The guard opens like a door pivoting on the right edge, & pulls out.
The center fan guard has two tabs at the top on each end that push in toward the center, & another tab in the middle at the bottom of the guard that pops up.
Step 7: Freezer panel. Remove the 4 screws in each corner. Push the thermostat back through the slot at the top, & also push the icemaker plug back through its slot.
FAST/HARD WAY: Pull carefully up & out from the top middle edge. Be careful because that sucker is SHARP! The back panel will bend vertically in the middle as you remove it, but it's flexible & will pop back into shape.
SLOW/EASY WAY: If you don't like bending the panel around the drawer slides, you can take off the slides. The metal rails have tabs that push in to release the whole slide assembly, which pulls out forward. You only need to take the rail housings off one side - when you go to remove the rear panel, just pull that side first. To release the upper section (that you already unscrewed in Step 4), left it up, bend in & pull out - the back end has a tab through the freezer wall. The lower plastic slide housing unscrews with 4 screws.
Step 8: Ice Dam. By now you should see the ice problem. Typically the entire evaporator tray is completely iced, along with some of the tubing. MELT IT ALL. Warm water applied with a turkey baster works well. Be careful not to puncture the coils because ... that will ruin your fridge.
Do all the ice melting while the drain is still plugged so it runs out into the freezer floor where you can sponge it up. If the meltwater goes out through the drain hole, it can flood the pan under the fridge - no big deal, just dirtier water & more mess.
The drain hole is near the front of the rear tray in the middle. It's pretty wide (1/2?) & short, only ~2 inches long. It goes straight down into a rubber "duck bill" grommet that's probably plugged up with gunk, that you access from the back of the fridge...
Step 9: Drain grommet. Pull out the fridge so you can access the back side. Remove the screws (6?) around the lower access panel, pop the power cord up & tilt the panel out of the way. The plastic tray under the fan is the evaporator tray - that's where the water SHOULD normally be dripping into & evaporating from.
Behind (technically in front of) the fan, there's a black drain slide into the tray that leads up to your plugged drain. Push the slide aside to see the drain. There's a rubber "duck bill" grommet on the end. Pull it off & clean it - it's no doubt plugged with gunk. Better yet, trim the opening very slightly so the hole is larger - see this site for photos.
Step 10: Put it all back together. Some tips: if you lived hard/fast & didn't remove the rails & rail housing, getting the freezer panel back in place . Make sure you slide the tray rails all the way out before you start trying to put the rear panel back. Bend the panel vertically along the middle so it springs back into place on each side. Again, wear gloves. Once it's in place, don't forget to run the thermostat wire & icemaker tube/plug out.
When you put the the top tray back, make sure it's all the way to the front before you pop the plastic pieces on each side back down, so the gears on each side are aligned in matching grooves. Otherwise your drawer will be crooked & probably won't slide.
Hope this helps. I have a Whirlpool GX2FGDXVY but these steps work on other models too including Maytag etc.
here is the whole exert video of the whole eplanation watch it,(https://youtu.be/lhuBR1sKx7E)or
kingsley
May 12, 2015 | Samsung RS261MDBP - 26 cu. ft. Side by...
The driver side window regulator?
I don't know for sure, but it sounds like at least one side of the window has come loose from the mechanism that raises and lowers it. Some cars have two plastic rivets or pins to connect the window to the mechanism. If one comes loose or breaks the window will behave as you described when you try to raise and lower it. If you want to fix it yourself you'll need to remove the armrest and inside door cover in order to see and access the window and raise/lower mechanism. Look for broken or loose pieces in the bottom of the door cavity. Hopefully you can see what's wrong and get replacement parts from the dealer.
Oct 01, 2017 | 1991 Toyota MR2
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
My chamberlain liftmaster works fine but when I open the garage it makes asqeaking grinding sound. what should I do?
the rails on the door frame that the door follows to raise and lower need lubrication,clean rails thoroughly then use a light weight grease and lube the rails and oil the rollers on the sides of the door that follow the rails,also oil the screw or chain that raises and lowers the door from the operator unit,this will make them operate easier and quieter
Apr 09, 2010 | liftmaster Chamberlain Garage Door Opener...
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Plastic piece to lower side rial broke
If you have one side piece that works, I would like to buy it from you. Email bluewriter24@yahoo.com Thanks.
Jul 05, 2008 | Childesigns Bellmont Crib
Missing parts
You should be able to take those pieces out of the bottom ends of the crib rail bother than that I'm not sure I have been looking for the plastic pieces for the top of the rail that you squeeze together to lower the side and I called the company and they said they don't carry any parts for this crib anymore. I wish we could all get these cribs together and switch pieces that we need to make at least some of these cribs work its pretty bad. Oh well I hope this helps you.
Apr 21, 2008 | Cosco 2 in 1 10-185-WHO Crib
Childesign Shelby crib replacement parts
You know I just purchased a Childesigns crib from a garage sale thatI thought had everything needed. When I got home, we found it was missing one top plastic rod. Of course nothing will work without that. I found this webpage that sells a VERY similar product. http://www.productsamerica.com/page65.html. It is not exact, but to be able to use the crib, this was a good option for us. Hope this helps.
Sep 06, 2007 | Childesigns Shelby Crib
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
