Question about Maytag Dryers
Gas dryer igniter fails to light up, igniter seems OK
  • sholla6297 Nov 15, 2009
    The dryer had finished one load of clothes, the heating stopped on the second load. When checked, I found the igniter was not even partially glowing, even though it is not broken or any thing. Could it be the igniter & not the gas valve that gone bad?
  • 10,515 Answers
First thing to check is make sure no one has set the dryer to air dry or fluff. It will not heat on either of these settings. Is the gas turned on to the dryer? Sometimes gas valves are mistaken for water valves and they get turned off during plumbing repairs. Next unplug the dryer and open the door. remove the four screws (2 on either side) of the door opening. Grasp the "goal posts" on either side of the door that makes up the dryer front and pull forward from the top of the front, lift front off from an angle. Close the dryer door. Plug the dryer back in and stand in front ***use caution do not stick hands inside the open cabinet with the dryer plugged in!!!!*** Start the dryer and and watch from the opening and listen. You should hear a click, see a light and then a fire. If you do not see a light the ignitor has likely failed if you see the light but no fire you likely need coils for the gas valve. The ignitor is carbon with a ceramic base and held in with 1 screw and a snap together wiring harness. The coils are the 2 black cylinders on top of the gas valve, 1 wiring harness to each and held in with phillips head screws. Unplug the dryer and turn off the gas to do this repair. the ignitor can either be checked with a ohms meter ($12 at Wal Mart) by touching the two pins coming out of the end of the igniter's harness or look for bubbling on the carbon element - do not touch the carbon end, skin oil will damage it and it is very delicate.To replace the coils disconnect the wiring harness remove the screws and bracket and replace coils. In rare cases one of your thermostats has failed. With the dryer unpluged disconnect wires to the thermostats and check for continuity with the ohms meter (you know your meter is on the correct setting when you touch the black and red leads together and the needle moves or if its digital changes to 0.000). Touch the leads to the terminals on the thermostats across from each other the meter should react as when tested for correct setting. If there is no reaction from the meter that thermostat is bad. In even more rare cases the timer may have failed, if all the thermostats are ok and the ignitor tests ok the timer has failed. If when the dryer front is off all systems appear to be functioning correctly you need to clean out your dryer exhaust completely from the back of the dryer to out of your home and gently wash your lint filter with soap and washer and dry. Good luck with this repair!!!!
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2009
  • 11,896 Answers
If igniter does provide a good strong spark, check the gas valve to make sure the spring is not worn. Make sure the unit is getting gas. If there is no gas, then the valve may need to be replaced.
  • Nate Stansfield
    Nate Stansfield Nov 15, 2009
    Either there is not enough gas flow to the igniter, or the igniter itself can also be bad. Even though it sparks to ignite, it has a heated rod inside that keeps the pilot lit. This piece can become dirty, sooted, and coroded and may require cleaning or replacement for best results. You can get parts and manual at repairclinic.com or partselect.com
    #3
Igniter stays lit and gas never comes on
Flame sensor is not shutting down at 1800f and allowing for ignition my first thought. HOW IT WORKS (my home movie)
Jul 31, 2012 | Maytag SDG3606A Gas Dryer
Gas will not turn on to heat dryer...igniter is ok...tested that...got new solinoids for gas valve seems to be back to timer but do not know for sure took that apart and points seem to be ok no hot spots...
Sometimes the heat sensor/ igniter gets carboned up and needs to be lightly sanded or cleaned for it to sense heat. That could prevent the main gas valve from opening and staying open. Also, does your unit have a heat limit switch or thermal switch that could be faulty? Check the wiring diagram.
Jun 12, 2010 | Whirlpool LEN2000PW Dryer
Gas Dryer lights but not drying. I have a White Westinghouse gas dryer on natural gas. It has a new vent hose and the filter screen is very clean and the vent area in the door is very clean. I even...
Sounds like the dryer coils are failing. The dryer may heat up in the beginning but once it runs for a few minutes the coils fail to open and let gas in. Check to see if you can hear the flame ignite after it has been running for a little while.
for a free video on this got to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Dryers
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Laundrette dryer producing no heat
Change out the igniter
Diamond Service
Apr 02, 2009 | LG DLE7177 Dryer
FAILS TO IGNITE ,UNPLUG &REPLUG AND WE HAVE IGNITION
suspect coils on gas valve they will breakdown after several ignitions and not open valve for burner to light
Nov 18, 2008 | Whirlpool LER7646E Dryer
No second ignition
replace the solenoid coils and it will work.
May 22, 2008 | Kenmore 74602 Gas Dryer
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
Dryers Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
