Question about Chrysler Sentry Key Immobilizer Bypass for Remote Start
Sentry key system won't let me start my jeep grand
  • 117 Answers
Wrong key or faulty antennae
Posted on Nov 15, 2009
What do I do ,my car shows empty tank logo and crossed key logo and won't start.
So it's a Jeep. This gives the solution. You have a fuse under the dash that is blown.
http://www.myjeeprocks.com/forums/showthread.php/19741-help-needed-with-sentry-key-light-on-dash-jeep-won-t-start!
Dec 23, 2015 | 2000 Jeep Grand Cherokee
Can a 02 jeep grand Cherokee work with out a sentry immobilizer system
Annette you can not immobolize the vehicle if the sentry system is on is your Cherokee petrol or diesel
Dec 19, 2014 | 2002 Jeep Grand Cherokee
I have a 99 jeep grand cherokee 4.7, the alarm went crazy and the wont start. guages dont budge and horn keeps honking and lights flashing. sentry key light is on in guage cluster any help
Sounds like you need to perform a relearn on the anti theft system, it's not recognizing the key if this happens with the key inserted. Might want to look online for a reset procedure for Jeep. GM has you keeping the key in the ignition in the on position for 10 minutes.
Jul 17, 2014 | 1999 Jeep Grand Cherokee
If i replace the ignition cylinder in my 1999 jeep grand cherokee will i have any problems with the anti theft system
You should not have a problem, the ignition cylinder only transmits the ohm reading from the key to the anti-theft module and it does not produce its own ohm reading or any kind of signal.
Oct 22, 2010 | 1999 Jeep Grand Cherokee
When jump starting my 99 jeep GC I accidentally hit the negative post with a pos cable (hot) large spark and subsequently it would crank but not start. Sentry key light came on steady as did check engine....
Not sure, but if Sentry Light stay on, by shorting it, the anti-theft system stay on ! Unplug the battery for 30min's reconnect it, and try it again, alot of chance that the anti-theft system will reprogram and will function normally ! You can go to a Local Dealer with your Jeep they will reprogram the system and everything will be fine ! For the Check Engine, need a OBD2 Code Scanner or a Garage/Dealer Scanner to know the Code Stored in the PCM and it will tell if PCM is okay too !
Aug 10, 2010 | 1999 Jeep Grand Cherokee
My Grand cherokee is not starting
If anyone has this problem also where you start your Jeep and it dies in about 2 seconds and the key symbol lights up on your dash I can help. I had this problem yesterday after jumping the battery, I had the correct key but it wouldn't read it. I had a locksmith come out and if you take off the steering column plastic there's a small black module in the column behind the key switch. Unplug that module for 5 minutes and it will reset. My Jeep started up right after. You MUST have the correct key though, mine is gray not sure about other years.
May 15, 2009 | 2004 Jeep Grand Cherokee
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
Sentry Key system won't let me start my Jeep Grand Cherokee
get a new key. you can easily bypass your alarm to ignition conection, worked for me!
Feb 12, 2009 | Chrysler Sentry Key Immobilizer Bypass for...
2001 Jeep Grand Cherokee won't Turnover
Jeep 2001 Grand Cherokee turns over but never starts. Doesn't run for 2 seconds and turn off. Immobilization indicator does light, flash once and remain on. All analog gauges on instrument panel are not functioning. Everything else electrically works in vehicle.
Oct 29, 2008 | 2001 Jeep Grand Cherokee
Chrysler Sentry Key Immobilizer Bypass for Remote Start Logo
1,070 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
