Question about Northstar Professional Series Pressure Washer 4000 PSI
My washer vibrates and has low pressure, whats wrong
My washer vibrates and has low pressure what wrong
  • Ruben Soto May 11, 2010
    look for the plag to check the oil on your pressure washer it sound like it is dry
  • 53 Answers
Add some oil to the hydrailic pump it may be low.
Posted on Nov 15, 2009
Low pressure
It sounds like the nozzle is worn or the wrong size ( too big )
Oct 23, 2014 | All-Power America Steele Products SPWE175...
There was a leak i undid the mottor and repaired it but some oil spilled out, now there is no leak but little pressure and mottor does not stop
A "chattering" pressure washer pump can be caused by many things. You could have a bent or damaged inlet line, or the water supply might be too low. Fixing these is simple, but checking on the water supply is critical. Never let the water supply run low for any extended period of time. Other causes of a chattering pump include water that is too hot, you may have air in the pump system or a stuck float valve. A power washer pump that is vibrating, but not chattering could be the result of air in the system or debris stuck in the valves. Catching these pressure washer problems early and knowing what causes them will save you a trip to the repair shop, especially when it comes to the low-water issue.
Troubleshooting Low Nozzle Pressure
Low nozzle pressure is a common complaint generally caused by one of the following:
1. Plugged nozzle tip.
2. Inlet screen plugged.
3. Insufficient flow in gallons per minute (not pressure) to the pump.
4. Unloader valve stuck open due to debris lodged under the check valve ball.
5. Customer use of shutoff-type quick connectors.
6. Plugged hose.
Troubleshooting Pressure Washer Soap Injector
When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following:
1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed.
2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting.
3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector.
4. If you have an adjustable nozzle, be sure it is in the low pressure position(away from the gun) to draw soap.
Thanks
Apr 01, 2012 | Garden
I have an ultimate x 1500 psi pressure washer & as soon as i turn this on, it shuts off can you tell me what im doing wrong
if it is a gas engine check for low oil level and or sending unit working properly, if it is an electric unit check for proper setting on pressure sending unit.
Aug 20, 2011 | Garden
My Karcer 5.55 pressure washer keeps cutting out, mainly when the high power lance is used. Can anyone help?
It could be the low oil cut off stitch, make sure the oil is clean and full, and the switch wiring is tight. Next is bad gas, water remover and octane booster can fix this, finally, replace the spark plug, as they are known to go bad quickly by the vibrations of these tools.
Mar 03, 2011 | Karcher Garden
I have a tpw 2200 pressure washer that has lost high pressure. i have low pressure but not high pressure.\r\n The machine i have is a titan tpw 2200 if some body can tell me what is wrong please help. ...
Pour a large amount of liquid TSP into the fresh water inlet where the garden hose connects and let is sit for a couple of days.
This is how I fixed my pressure problem
Aug 04, 2010 | Garden
Code LF on Kenmore Oasis washing machine.
Hi
Error code LF means long fill. This means that analog water level pressure sensor signal is out of range or the water pressure is very low. The analog pressure sensor is a component on the machine control board. The normal water pressure is 100-200 PSI, when the pressure below 40 PSI then this error occurs. Verify the pressure at all other water sources in the house and check if its low at all places, if its low then contact the water company. Also check the inlet water hoses if they are kinked. Inspect the inlet water valve as well.
If you find no problems with the air hose or water pressure and its connections, then the machine control board would need to be replaced.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Whirlpool WTW6700TW Top Load Stacked...
I have a Kenmore front loader washing machine that won't spin or drain. What is wrong?
Top 10 frontload washer problems
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the termister/heater is out.
Feb 07, 2010 | Washing Machines
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Northstar Professional Series Pressure Washer 4000 PSI Logo
318 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
