Question about Cell Phones
When I press the SPEAKER button, I hear no dial tone; if I try to use the speaker to answer a call, I can't hear the caller. I have replaced the batteries - twice.
  • big_bucko_on Nov 15, 2009
    This is not a cell phone; it is an AT&T desktop plugged into the wall Model CL2939 speaker phone.
  • 838 Answers
Dear, that is not a battery issue, If you can't here the ring/answer the phone on loud speaker, it is definitely speaker problem, either the loudspeaker is damaged or the circuit on main board damaged or broken. Please try check the circuit on main board passing the electron properly or working properly and the speaker is also OK. If not, try repair the damaged circuit or replace damaged speaker.Check the sound IC/processor is also fine if necessary. That's all. Hope it will help you to fix. Thanks for joining Fixya. Good Luck
Posted on Nov 15, 2009
  • Cell Phones Master
  • 13,433 Answers
Could you post the brand and model of your cell phone.
Can not hear dial tone or hear caller / can hear on speaker call
Most likely that it is the speaker on the handheld part of the phone. Your sound comes from the base itself when you put your current connection on Speaker-Call. So if you cannot hear the dial tone OR the person on the other end unless on "speaker" it's just the handheld and I believe there are places online you can purchase JUST that part if needed.
Oct 19, 2014 | AT&T ATT-1855 Corded Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
My uniden tect1580 doesn't ring
First thing to try is while the phone is in "On-Hook" mode, press the up key on the handset several times, you should hear a beep each time you press the button and the display should show "Ringer Volume" with a graduating series of bars. If the display shows as above, but you do not hear any rings, try pressing the "Speaker" button and listen for the dial tone. Most of the time on these phones, it is a simple matter of turning up the ringer volume, but sometimes, the handsfree speaker (Which also acts as the ringer speaker) goes bad. If the speaker is bad, it is a fairly easy replacement if you are handy with a soldering iron.
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
Callers can hear me but I can't hear them or tones - nokia B65. I can caal, and callers can hear me, but I can't hear them. I also can't hear key tones or any other sounds
the problem of your fon is the speaker, it controls the voice of the person that you are talking for and it also control the keypad tones, so replace it! buy to the cellshop a SPEAKER,
Apr 02, 2009 | Nokia Cell Phones
CHANGE RECORDED MESSAGE
To change the greeting you need to either pick up the phone or press speaker phone then dial *38 then 1 then you will hear a beep/call tone. When you hear that tone record your message/greeting. Once you are finished press the auto dial/store button. If your are satisfied with that message hang up or press speaker phone again to end the call. If you would like to clear the message, then right after you hit auto dial/store you will hear a beep/call tone press 0 to clear or 1 to rerecord.
Dec 08, 2008 | Panasonic KX-T7630 Corded Phone
Changing settings on innovage telephone
hi big al,
on my phone you hit SET/SAVE, press UP/DOWN to find the function you want, press SET/SAVE again to select, press UP/DOWN key to program. press SET/SAVE to confirm. i can email you a copy of my manual if you'd like. my email is all8upinwv@yahoo.com hope this helps.
tammy
Apr 19, 2008 | Innovage Speaker/Caller ID* LCD Touch...
Phone rings but when answered the caller can not be heard.
Your ear speaker is bad. You may need to replace it.. This one made by HTC. You can check on Ebay for replacement part. Other issue could be is the hardware part of the ear speaker may be broken or defected will cause loosing contact with the main circuit or you can say it is short. Only solution is open the phone and check for that area to see for any defective.
Apr 21, 2007 | O2 Xda IIs Pocket PC
Cell Phones Logo
169 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
