Question about Acer AL1912 19" LCD Monitor
Acer al1912 19" black
Started with a band of coloured pixels down the right side of the screen. now there is nothing. turns on fine but after the acer logo, it says no signal and goes black.
thanks in advance.
See if the problem happends in safe mode ( while booting hit F8 and aboot menu wil come up) if everything works fine then your issue will be the driver or a resulition that the display does not support or a refresh rate. Frist try to change the Res to a lower one and common (1024X768 or 800X600) also change the refresh to somewhere 70 to 75 and reboot if this dosent fix the problem try updating your video driver in safe mode
Posted on Jul 09, 2008
RED COLOUR ALL OVER SCREEN
this sounds like a problem with either the screen or, more likely, the graphics chip. If you can't replace the graphics chip (if it's not on a separate removable card), I'm afraid you'll need to bin it and buy a new machine.
The acer logo is displayed before the graphics drivers or windows has started.
Apr 13, 2013 | Acer AL2016W 20" LCD Monitor
Tip
VirtualDub Filters best use, Delogo vs. Logoaway with examples
This full popular tip sadly was overwritten without the benefit of backup I have found the original screendumps that compare Delogo and Logoaway, the former will always come out on top as it has the ability to set which frames the repair will apply to 34510-34520 will only repair 20 frames starting at 34510 then only other filter that will allow you to do this is Donald Graft's Logo v1.72b filter that can also be used for logo removal but takes a bit longer check out my tip HERE on how best to do this
Delogo Filter
This filter excels at removing translucent (allowing some backgound to pass through) logos like those at the Disney channel that have partial colour information behind the logo
It is also very good at removing and opaque (allowing nothing to pass through) and semi-transparent (allowing almost all colour information to pass through)
Logoaway Filter
The UGLARM setting on this filter gives similar results to the DeLogo Filter when the pixel aspect ratio is set to 1:1 that merges the info in a 45 degree cross (like the right-hand side example) the biggest drawback it that you can as yet select the frames that you want to repair like in DeLogo and Logo v1.72 from Donald Graft's website.
on Jan 28, 2010 | Philips DivX DVD Player
I have an Acer Laptop and it has developed a band down the bottom of the screen from left to right of stripped colors about 1.5 inches high.How can I remove it??
There is no way to remove the colour bands, the only option is to replace the screen, go to www.ebay.com Type make and model of laptop, refine search to screen, this will give a idea on pricing.
Jun 10, 2012 | Acer Aspire 1414 Notebook
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
Hi, I am using an Acer Aspire m3100 desktop PC, and for the past day now it has been acting up. I think it may have either something to do with the overall hardware or the operating system. What...
i,m thinking that the problem is with the hard drive or ram stick
keep an eye out for other replies as there are a couple of experts conversant with laptop problems that can be more accurate
Mar 02, 2017 | Computers & Internet
Acer Orbicam Colour Problem!
The display is gone. Replace it.
Nov 29, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
ACER Aspire One screen black out after OS start up.
start the notebook in safe mode and change the pixels to a lower pixel
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer AL1912 19" LCD Monitor Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
