Question about Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31
My saw motor doesn't always start. it will buzz but won't turn on. Any ideas?
  • 8,404 Answers
I believe you have a dead spot in your motor or there is a problem with the start capacitor. Next time it does this, turn the switch off, turn the blade a few degrees by hand and turn it on again to see if it will start. I'm leaning toward the capacitor though a saw this large, it could equally be the motor. The switch is good, right? One leg of the switch is not burned is it?
Let me know what you find out. Post a comment to this question.
Thanks for your interest inFixYa.com
please vote
thanks
a
Posted on Nov 15, 2009
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
Jul 09, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When i turn it on, it buzzes and doesn't start
Sounds like the control board won't allow the motor to begin the cycle. Contact a professional for an accurate diagnosis.
Sep 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
My 1998 Dodge Ram 1500 idles high upon starting it.
Check temp gauge if It doesn't get to normal heat range it won't idle. Your thermostat needs replacing.
Aug 23, 2012 | 2001 Dodge Ram 1500 Truck 2WD
Motor won't turn on
CHECK POWER AT THE PUMP, MOTOR BUZZES ? YES CHECK TO SEE IF ROTOR TURNS, YES CLEAN START SWITCH, HAVE CAPACITORS CHECKED , NO ROTOR DOESN'T TURN MOTOR WILL NEED TO BE SERVICED. ROTOR MAY HAVE RUSTED TO STATOR OR LOCKED UP BEARING .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 15, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Radial saw motor just buzzes.
It sounds like the start circuit is shot on the motor of the radial saw. It is trying to start, (the buzzing sound), but the start is not is burnt out, and therefore the run winding is drawing excessive amperage trying to start the motor (a job it is not designed to do) and eventually builds a amp draw in excess of the circuit. You will have to determine which is cheaper a new motor, or a new saw.
Hope this helps
Sep 25, 2009 | Saws
When I turn on my B&D band saw the motor buzzes and will not start.
The motor start capacitor has failed. Pull it off the motor and go to a motor shop- for a new one.
Jul 14, 2009 | Black & Decker Saws
Delta 10" 3 Hp, 230V, Single Phase, Right Tilt Unisaw® 36 R31 Logo
156 people viewed this question
Top Delta Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Delta Measuring Tool and Sensor Expert? Answer questions, earn points and help others
