Replace power switch
In replacing the power switch, which terminals do I plug the green and red wires to? Is it the green and red terminals?
  • 788 Answers
No, The Green wire or wires are ground and go directly or in-directly to the frame or casing.
The White and Black are your two outside leads.
One is neutral and the other is hot.
If you run the green wire to either of these two leads, you will have a major problem..
Posted on Nov 15, 2009
Switching 3 prong cord to a 4 prong cord
if theres a wire from the center terminal on the dryer terminal board going to the dryer case disconnect it,then Red & Black on the cord go to the outer 2 terminals on the dryer terminal board,the White goes to the terminal in the center between where you put the Red & Black wires this is the Neutral wire,then the Green wire connects to any metallic portion on the dryer case as this is the SAFETY Ground wire and also Red & Black can go on either outer terminal on the dryer terminal board as these are not polarity sensitive because its A.C. power so wire it on the dryer terminal board as in (RED-WHITE-BLACK) on the dryer terminal strip and connect the GREEN to any Metallic portion of the dryer case
Dec 30, 2012 | GE Profile Harmony DPGT750EC Electric...
Want to switch a 4 prong plug to a 3 prong plug on a kenmore 90 series elec. dryer
ok,, easy one,, unplug, take the cover off of the terminal cover,, take your old cord off, on the 4 prong you will have a red, black, white,and green wire,, matche the colors up red on right, white in middle, black on left, the green wire will go on a green screw that is near the terminal block with a white wire going to it, take the white wire off and put it with the white wire on the terminal block,, screw the green wire to the green screw,, and relpace cove and your done
Jan 19, 2011 | Kenmore Dryers
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Jan 14, 2010 | Ford F-250 Cars & Trucks
I have a whirlpool dryer ler5624bwo it is zaping us how is the plug wired to the back i think maybe some one switched the black or red power for the white neutral the plug is a 4 wire 2 rectangular on...
Black and red go to the outside terminals, white goes to the middle, and green goes to the frame of the machine.  You can look up at the wires coming down to the plug terminal and match up the colors.  Your ground is green and goes to the frame of the machine.  Green is the wire that is supposed to pop the breaker and prevent you from getting shocked so make sure you hook it up to the frame.
Oct 24, 2009 | Whirlpool LER5636P Electric Dryer
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
