Question about Samsung Eternity Cell Phone
The screen is unresponsive, and no matter what I do, it won't respond.
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
Jan 20, 2014 | Sharp FX Plus
Go 720 unresponsive when at legal notice screen and when asked if wanting to connect to computer. having screen response problem since last update 2 days ago. does not seem to be a unresponsive screen...
I may not be giving you any regarding knowledge about it but its very true that people are liable to know about the elated aspect of the above query. I surely recommend you to concern any professional regarding your query as I think it will help a lot.
https://www.structuredsettlement-quotes.com/
Nov 18, 2013 | Tomtom GO 720 GPS Receiver
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
Touch screen unresponsive
Whats the model number and type? A designer with the large touch screen can lose its programming on the screen and needs recalibrating. Models can be different and some have codes that need to be entered. Respond to this with the info and I will look it up and reply.
Derek
Jan 21, 2011 | Husqvarna Sewing Machines
Touch screen is unresponsive
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Oct 26, 2010 | Garmin GPS
Panafax UF-895 - keyboard dead
cracked keyboard from a heavy hand. Will need a tech to replace.
May 05, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
IPaq rx3115 screen unresponsive
Bad screen if the driver was bad they would tell you that you are having a problem with the driver
Feb 07, 2009 | HP iPAQ RX3115 Pocket PC
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
Samsung Eternity  Cell Phone Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
