The bottom half of my screen is shaking like a "non" TV channel.... I restarted it, and turned it off and back on again and it continued. The shaking occurs every 2 seconds and is spreading higher now. It is shaking of the visual on the screen- not the actual machine.
  • 458 Answers
If you can.. Plug a Desktop Monitor into the Serial Port of the Laptop..You do This To See If It Shows Same Thing Onto A Different Screen.. If It Does, You Are Having Video Issues.. Which Were Most Likely Caused From Overheating Issues..
If It Shows Normal On The External Monitor, Yet Still Does Same THing On The Laptops Screen, Then You Have 1 of 2 Issues... Either You Need To Replace The Display Due To A Faulty Circuit Board On The Backside Of The Screen... Or Your Display Cable Is Loose And Needs To Be Fully Plugged Into It's Port, Or The Display Cable Is Failing..
Posted on Nov 15, 2009
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Recorder is not showing tv listings
I spoke with Toshiba tech support today (800-631-3811). They have an advanced services team that focuses on TV Guide On Screen. Learned the following:
- The TV Guide On Screen signal is updated 4x / day and is broadcast by your service provider
- The broadcast channel varies depending on what the service provider chooses (though typically a major network or PBS station)
- TV Guide On Screen has been doing some reprogramming and updates recently and this has resulted in many sporadic outages
If you ARE not receiving your listings, it's one of two things - either your DVR or the signal from the cable company.
- If you are having issues, call Toshiba and let them know, they will walk through some basic troubleshooting to narrow down if the problem is the DVR or the TV Guide On Screen signal.
- If the issue is the TV Guide On Screen signal, they will be able to report the issue to TV Guide On Screen and let them know their is an issue.
After that - it's in someone else's hands!
Feb 05, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Shaking screen
Check the 9v regulator Ic2p01 on the signal board for correct regulation 8.9 to 9.1 volts. If voltage at the output is under 8.9v, replace the regulator Ic. Always replace C2p05 100 Ufd 16 V on this set and that should take care of the shakes but you may want the tech to go ahead and ESR some of the other troublesome caps throughout the Tv. He'll know what you mean. Many of the 100mf caps replace automatically. Several others will have a questionable ESR and should be replaced. Caps are inexpensive, but probing with an ESR meter is somewhat labor intensive so you miht discuss with the tech just how far you want him to go testing for bad caps.
A Mits is a great Tv and this repair is clearly worth it..
Bill
Dec 19, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Blue rectangle at bottom half of screen??
Try to change the Caption mode: Press ACTION to display the MAIN MENU Select TV - CAPTION - OFF It should help.
Sep 12, 2005 | Panasonic PV-M2058 20 in. Combo
Computers & Internet Logo
594 people viewed this question
David Payne
David Payne
