I have a Breezair evaporative cooling system. The other day it was running for a long time at full fan and then a smell of burning came from all of the vents. It was 39C outside. Turned it off immediately. Tried it again next day and working fine but I did not run it at full fan speed. what caused this burnin smell? and is it safe to use.
Millerba says it is "probably" safe to use. Will he pay up if he is wrong and your house burns down with you in it? Yes 39 degrees is hot!!
It IS economical to replace the motor provided the general condition of the unit is OK. Call a REAL expert.
Posted on Jan 23, 2010
  • 8,404 Answers
You probably burned up the high speed part of your motor. It is probably safe to use but it will operate at a reduced efficiency. If you are asking me if you should continue to use it, first you would have to tell me what 39 degrees C is, if that is hot, I'd say plan on replacing it pretty soon.
You may be able to replace the motor, but you will probably find that it is not economically feasable.
Thank you for your interest in FixYa.com
please vote
thanks
a
Posted on Nov 15, 2009
My breezair evaporative cooling can not cool.
Maybe you're expecting too much. Evaporative cooling doesn't work really well. It's function depends on evaporating a lot of water into the air. If the air in your room doesn't have a really low humidity (really dry air), then evaporation can slow way down or even stop regardless of how fast the fan is blowing.
Jan 02, 2015 | Heating & Cooling
My breezair evaporative cooling system can not cool.the air flow is very worm,anyone can tell me this problem?
what is the weather like is it humid ?
Humid weather will render any evaporative cooler ineffective !
Have you got the windows and doors open to the building ?
Evaporative cooling relies on putting water in the air and pumping the air out of the building. If it is humid the air already contains water and no extra water is added to the air and no cooling occurs.
Smoke smells when ac on nissan sentra
The speed control of your fan has resisters that are in the venting system to blow air on them to keep them cool. If they overheat and or burn you will lose your low and medium speeds of the fan. If you run the fan at full see if the smell goes away. Your engine could be burning oil on the outside of the engine block, make sure that the weatherstrip where your hood meets the fresh air intake grill is sealing tight.
Nov 26, 2013 | 2001 Nissan Sentra
WHERE IS THE WIRING HARNESS THAT WOULD CAUSE THE EVAPORATOR FAN TO STOP
I would look for a fuse somewhere. If you've found the board, simply smell the board. One of the few good things about an electrical short (creating the smell), is that the smell sticks with the problem.
Assumptions:
When checking the power to the motor, consider that there is typically a temp sensor that tells it when to kick on and off. If the entire system isn't running, it likely won't ever get to that point, thus no power reading.
Follow the smell.
Also, the good thing about motors is that you can hook up just about any power to it (within reason), and "bump test" it. You'll just bump the power to it, to see if the fan bumps on. Not something you'll want to do for an extended period of time, but it'll serve its purpose.
Sep 02, 2012 | KitchenAid Superba Architect KSCS25INSS...
Freezer is all deforsted. Fridge is 5 years old. We smelled a burning smell 2 nights ago and now everything is defrosted. We couldnt tell where the smell was coming from in our house. Motor is running....
If the evaporator (freezer) fan and the condensor (bottom rear) fan are both running but you have no cooling at all, the odor you smelled was probably the compressor start relay/overload device. It would be in your best interest to have a professional service technician look at it. Proper repair could mean the difference between a $60 part, or a $300 compressor. Prices are for the part only.
Dec 23, 2009 | Refrigerators
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
Model 106.53632300 couple of days ago smelled something (burned electrical type smell). Now both fridge and freezer not cooling. Cooling fan in back on bottom is running.
you may have a fried start or run cap and hopefully not a spendy board like everything runs on these days....bad caps(capacitors) will cause compressor not to start and run but arent needed for fans to kick on ....
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Aug 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
244 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
