Question about Cuisinart DTC-975 Coffee Maker
I need another top for the pot. Where can I find it?
Can you put a Greek coffee maker on a glass top new coker
There are essentially two types of Coffee Maker, one where the water is heated by an immersion element (where the water is heated by electricity), and a Boiling Water Coffee maker, where you heat the pot on a stove top element either by gas or electric heat.
(If you hve one of the electric immersion ones, don't do what a famous comedy showed and place the coffee pot on the HOT SURFACE of the cooker.
While the first pot of coffee might get warm, the idea is to heat the water from the inside, then have the coffee brewed by the machine after.
Is there a MODEL or NAME on the BOTTOM of the maker?
Google or search for these things first and get back to this board if that does not help.
If I understand your question (sort of) , are you asking if a Metal pot can be placed on the top of an INDUCTION type cooktop, where the special rings Induce a current of electricity into the bottom of the fry-pan or Stock-type pot to boil water or fry items in oils.
I do not know if there is any special method used in Greece to make coffee. Please provide details, if you were not having a 'glass' cooktop.
After some research, a 'Greek' coffee maker or 'Bricki', is a stainless steel or copper pot used to boil the water and grinds together without any extra filtering.
So, the Original Poster needs to determine what the pot is made from (The type of metal), and the other part is what type of cooker element is underneath the 'glass' part of the stove.
The Test is if you turn on the element, and watch it, does it glow red underneath or not?
If it glows red, then the heating elements are embedded into the glass and the stove functions similar to a regular electric range.
If the 'glass' portion is black and does not glow red without a pot on the top of it, then it is an INDUCTION element, and the Inductor NEEDS a metal pot on top to induce a magnetic field to make the bottom of the pot warm up.
Based on the Size of the Pots shown in pictures, it may be too small to function in your particular cooker. A model of the cooker would help. The label is usually on the door frame to the oven or a logo or name near the contol knobs.
Sep 06, 2017 | Coffee Makers & Espresso Machines
What are the better ways to clean oily pots and pans without using detergent?
Pots and pans are regular using tools in kitchen.Every day we use these tools to cook.
These type of tools need to wash daily.There are some digertent category which are using for wash pots and pans.I dont know there is another way or not to wash pots and pans without detergent.But try here maybe this help you.
The Best Pots and Pans Sets Our Top 5
Oct 17, 2016 | Dishwashers
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
Can't get the top off of a stainless steel pot. The top got on the bottom and I can't get them apart.
Try heating the pot on the stove - just a slight bit because its empty. The pot and lid probably sealed themselves together becausethey were put away while they were warm, and as they cooled, the air in them shrank, creating a vacuum.
Dec 19, 2012 | Crock Pots & Slow Cookers
Dont know how to use stovetop coffee pot (corningware). To be used with heat dispering mat or directly over the gas range?
Same problem...HELP PLEASE
I have the same pot and I can almost taste the coffee but not game to try it until I know how.
May 11, 2009 | Coffee Makers & Espresso Machines
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Replaceing glass top on a stove
The top can be replaced but it is expensive. Your range is less than a year old call a local servicer to see if there may be warranty available to cover this problem it may not cost you anything. Good luck.
Jan 15, 2009 | GE JBP64 CleanDesign Electric Kitchen...
20 Qt. Mod: RO220 Roaster Oven
MY CROCK POT PLATE IS BROKEN, I WOULD LIKE TO KNOW IF I CAN REPLEACE IT, AND IF A NEED AN US ADDRESS OR IT CAN BE MY ADDRESS IN MEXICO. AND THE COSTS. THANK YOU.... MY MODEL IS 5855 OVAL PROGRAMABLE. THANK YOU LUCY
Sep 21, 2008 | Rival 38601 Smart Pot 6-Quart
Coffee pot top
as far as i can tell you cant just buy a lid, mabe on ebay instead of buying a whole new pot or call customer care at 1-800-835-3278. Let them know you just need a replacement see what they say. Heres the item number for it on ebay, only one day left at $16.99 200133333009 , and heres the link http://cgi.ebay.com/New-Coleman-Stainless-Steel-12-Cup-Coffee-Pot-805D712T_W0QQitemZ200133333009QQihZ010QQcategoryZ87143QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 30, 2007 | Coleman 805D712T
Cuisinart DTC-975 Coffee Maker Logo
66 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
