Question about Venta Airwasher VS370 2 Gallon Humidifier
How often do i need to change the filter? - Venta Airwasher VS370 2 Gallon Humidifier
  • 43,501 Answers
From the quick research that I did I'm finding 100 hours. That will vary very significantly depending on the mineral content (hardness) of your water. If you have alot of mineral in your water the filter may have to be changed much more often to maintain good operation of the unit.
Posted on Nov 15, 2009
Is there a filter I need to replace in the Walgreens humidifier model # 2055? Tks
Most humidifier's have a filter I would google make and model along with filter replacement you should be able to pick up a on line manual to get correct size and how to change it .
Jan 03, 2018 | Walgreens Humidifiers
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Nov 19, 2010 | Sunbeam (0013871361) Humidifier
How can i change the filter in my bionaire model bcm 7207
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
Feb 26, 2010 | Bionaire BCM7207-U Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
I have a Venta VS370 humidifier which works fine immediately after I change the filter but after a few days the vapour stream diminishes significantly and it ceases to be effective: is this a malfunction?
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Mar 08, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Change filter
http://www.ontimemall.com/How_to_change_990-13_Pad.pdf
Nov 16, 2008 | General Filters 1042-LH Humidifier
Filter changing
I had the manual..phamplet and didn
t know I had it It was attached to the bill.........it's so small, you don't think it's anything..but it's the manual!
Mar 06, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Venta Airwasher VS370 2 Gallon Humidifier Logo
103 people viewed this question
Top Venta Humidifiers Experts
Paul Carew
Dennis
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
