Question about Dryers
Frigidaire LEQ215EE1 dryer making thumping noise
My electric, front loader frigidaire dryer has a thumping noise. Model number LEQ215EE1 What can I do to fix it?
    Problem Solver:
  • 6 Answers
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Posted on Nov 15, 2009
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
What is the thumping sound in my frigidaire front loader dryer?
Hi Denise, thank you for your question. There could be a few possibilities of why your Frigidaire dryer is making a thumping noise. To better assist you; may I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you - Z.
Apr 26, 2014 | Frigidaire Refrigerators
Dryer makes a thumping noise when drum is turning its an electric fridgidare de5520rw2
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
Oct 02, 2009 | Frigidaire Dryers
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Frigidaire dryer making rumbling noise .
I work for an Appliance Wholesale Company at www.appliancepartsonline.net
Is the dishwasher a front loader or a top loader? That will matter!
Give me the model number of the unit and I will tell you how to stop the "rumbling"
thnx
info@appliancepartsonline.net
Feb 16, 2009 | Frigidaire Dryers
My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
220 people viewed this question
Top Dryers Experts
