Question about Canon ES6500 Hi-8 Analog Camcorder
Canon ES6000 camcorder will not eject tape. Power indicator flashes. ''Eject'' message flashes.
  • 883 Answers
SOURCE: removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Posted on Jun 06, 2007
SOURCE: Message reads eject. won't eject
Ihatecanon, Tried the steps you provided above with no luck. Then decided to gently smack the camera twice on the right-top side of the tape compartment. It freaking worked the first time. Got this idea by watching Eric Cartman on South Park... No, really. I read about this in another forum. It's a quick $150 back in your pocket. Just think. You sent the camera to their tech guys and paid them 150 to SMACK-IT :)
Posted on Sep 29, 2007
ctf1800
  • 4402 Answers
SOURCE: error code EO3
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Feb 07, 2008
SOURCE: Canon ZR 70 Camcorder
press eject!!!!!
Posted on Jul 15, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
Eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Dec 28, 2009 | Canon Optura Pi Mini DV Digital Camcorder
    Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
    Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
    Jun 24, 2009 | Canon ES75 Camcorder
    Canon ZR-800 Mini DV Camcorder tape stuck
    The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
    Feb 23, 2009 | JVC GR-DV800U Camcorder
    Canon Elura 100 won't eject tape
    I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
    Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
    Eject tape message
    We get the eject message and then it will not eject tape.  Any suggestions
    Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
    C:32:11 message flashes, cassette eject won't work, camera doesn't work
    Just had this problem myself... called Sony. Here is what I did to fix this:
    1. Turn off power
    2. Open the LCD Display
    3. Press "Reset" with paperclip/pen
    4. Unplug ANY wires connected to the camcorder
    5. Eject battery
    6. Plug in DC charger
    7. Power on
    8. Attempt to eject tape
    9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
    10. The metal door *should* pop out and allow you to withdraw the tape.
    I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
    Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
    No power and unable to eject the tape
    check the small fuse in the power supply if you can open the your camera...indicate letter k and n at the power supply section...
    Oct 15, 2006 | Canon ZR100 Mini DV Digital Camcorder
    Canon ES6500 Hi-8 Analog Camcorder Logo
    330 people viewed this question
    Top Canon Video Cameras Experts
    Chance Miller
    Lawrence Oravetz
    abdul rauf
    abdul rauf
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
