Question about Canon FAX-L380 Plain Paper Laser
Install cartridge on the display but the cartridge is ok
  • 1,219 Answers
Hi, check the crg. is there any leftover from toner band? It also can be tht is problem with crg contact on fax, try with wd-40 small amounts if not send the message
Posted on Apr 30, 2010
What's your question?my printer hp laser jet 400 pro is displaying use black cartridge install press ok to continue and I press ok change the cartridge still the same things
If you install a cartridge that has previously been installed you will get this warning message. Once you press OK you should be able to print normally. This message is to ensure you do not put the old cartridge in by mistake (yes it happens), or someone does not try to sell you a used cartridge as new.
Aug 20, 2015 | HP Office Equipment & Supplies
Our copier (model x5650) stopped while receiving several pages , and displayed FAX IN MEMORY COLOR AND BLACK INK CARTRIDGE NEEDS REPLACED. I installed a new black cartridge , however the display...
YOU NEED TO LET THE PRINTER RE-ALIGN ITSELF AFTER INSTALLING PRINT CARTRIDGES, THE PRINTER SHOULD HAVE PAPER IN IT TO DO THIS, THE TEST PAGE PRINTED WILL THEN NEED TO BE PLACED IN THE PRINTER ON THE GLASS, PRESS SCAN, THIS SHOULS RESET YOUR PRINTER.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Lexmark C533DN InkJet Printer
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
Install ink cartridges for an Epson 315 workforce
If you do not want to go through the guide, here is a quick instruction on how to insert the ink cartridge.
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. If an ink cartridge is low or expended, you see a message on the WorkForce 310 Series LCD display screen indicating which color to replace. Press OK. If you're replacing a cartridge before you see a message on the WorkForce 310 Series LCD display screen, press the ink.9.7.1.jpg Copy button, press ink.9.7.2.jpg Menu, press ink.9.7.3.jpg or ink.9.7.4.jpg to select Maintenance, and press OK. Then select Ink Cartridge Replacement and press OK. 1. Open the scanner, then open the cartridge cover. ink.9.7.5.jpg 2. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.9.7.6.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 3. Before you open the new cartridge package, shake it four or five times. Then remove it from the package. ink.9.7.7.jpg Caution:
Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 4. Remove the yellow tape from the bottom of the ink cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 5. Insert the new ink cartridge into the holder and push it down until it clicks into place. 6. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place. ink.9.7.8.jpg 7. Close the scanner. 8. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Go through your user manual for further guide on how to install ink.
Jan 16, 2011 | Epson Office Equipment & Supplies
Installed new cartridge still says low in ink
  1. Disconnect the power cable.
  2. Hold down On/Off button.
  3. Reconnect the power cable.
  4. With the power button still down, press the Stop/Reset button twice.
  5. Release the On/Off button.
  6. The printer is now in factory mode (wait until idle is displayed)
  7. Press the right arrow button (next to the OK button) repeatedly until Shipping Mode 3 is displayed.
  8. Press the OK Button
  9. Wait until "Without Cleaning" is displayed and then press the Stop/Reset button once.
  10. A test page should print.
  11. Open the cover. (the cartridges should position themselves at the far left - the cartridge removal location)
  12. Disconnect the power cable.
  13. Remove both cartridges.
  14. Close the cover.
  15. Reconnect the power cable.
  16. Press the On/Off button.
  17. Wait until a Replace Cartridges message is displayed. Now insert the cartridges.
  18. Wait until the printer is operating in its normal mode. The display shows the normal start menu
Dec 24, 2010 | Canon PIXMA MP470 All-in-One Printer
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
NX415 inkjet catridge refill
This is what I found on the Web. You can download the Manual if you like. Click on link below. Not able to put all here, do to limitation.
http://files.support.epson.com/htmldocs/nx415_/nx415_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones.Caution: not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1.
Turn on your Epson printer.
2.
If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press or OK (NX410 Series).
If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Your printer model may vary from the ones shown in this section, but the procedures are the same.
Do not open the ink cartridge cover while the print head is moving.
Apr 04, 2010 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
Apr 30, 2009 | Krups XP7230 Compact Super Automatic...
How do you install ink into a hp c4180
Hi bogtank, here are the instruction on how to install the ink cartridges.
  1. Open print cartridge door, make sure the print carriage moves to the right, if it does not move to the right, turn the device off, then turn it back on again.
  2. Remove the tape from both cartridges, making sure you don't touch the copper coloured contacts.
  3. Hold the cartridge with the HP logo on top.
  4. Insert the tri-colour cartridge in the left cartridge slot, and the black cartridge in the right slot.
  5. Make sure you push the cartridges in firmly until they snap into place.
  6. Make sure you have paper loaded in the tray and close the print cartridge door.
  7. Press OK at the promt on the display to start print cartridge allignment.
  8. Check the display for status then press OK.
Nov 13, 2008 | HP Office Equipment & Supplies
Canon FAX-L380 Plain Paper Laser Logo
178 people viewed this question
old marine
old marine
