Question about Acomdata HD500UHE5-72 Hard Drive
Acomdata 500 GB doesn't show on XP or OSX. All I get is a faint ticking noise about 1 per second. Is it toast?
  • 28 Answers
50/50. You need to install it inside a PC to see if the file are recoverable or not. most external drive have power supply issues..
Posted on Nov 15, 2009
ACOMDATA HD160U2E-509 NOISE AND FLASHING RED AND BLUE
My External HDD in your picture :D
Turn your HDD off & back on
Jun 11, 2011 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
Western Digital 500 Gig Essential wont show on my desktop osx I have tried all of the things suggested by WD - how can i get my data back ? HELP ! Steve
Also check it on some other system, as per your data is concerned sometimes the card to which hard drive is attached does not work if this will be the case, then the hard drive is ok your data will be save
Oct 05, 2009 | Western Digital My Book Essential 500GB...
My hd 500 won't mount. CD Part is recognized,
YOu should try a shorted _SCREENED_ USB cable it sounds like this is faulty
Aug 09, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Running mac osx my acomdata external drive lights
This is the solution that worked for me.
Luckily I have another external drive of the exact same model that is working fine.
I used the power supply from the good working model and plugged it into the bad drive. The bad drive booted right up. Evidently the power supply was the issue, not the drive itself.
Even though the bad power supply had enough juice to light up the drive, it was not able to make the drive spin correctly.
Mar 25, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
How to eject (exit) from nomad mobile desktop program/acomdata e5
Have you tried changing your display size for you computers desktop?
Try a higher resolution first, then if that doesn't work try a lower resolution.
Most like the items are there and your display resolution is the problem.
Jan 03, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Acomdata external harddrive is not recognize on vista
I had a similar issue with windows 2008 and windows 7. the drive lost all its info and had to be reinitialized under both of those O.S.'s..
You can try that as long as it doesn't have any data you need.. Once you do that the drive will work and you can start using it. The file system under vista and above is slightly different than xp.
Sep 12, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Problem 2
The feint ticking noise usually indicates a dead hard drive.
The heads are flicking back and forth at random and make the ticking noise you hear.
The drive can still be detected because the physical hard drive and the controller board on it are in reality 2 seperate components working together. So the controller board is also trying to access the hard drive without luck.
If you have not dropped the unit or knocked it over etc, then chances are the controller board is what has died and therfore you still cannot access the drive. You may get lucky in finding a new controller board to replace a failed one and that will also get your data back.
May 14, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Acomdata HD500UHE5-72 Hard Drive Logo
541 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
