Question about Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 265w voice command stopped working. Any suggestion on what to check?
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Posted on Jan 19, 2010
I have a Garmin Nuvi 265w and it stopped saying street names. How can i get it to say street names again?
From your main menu, tap tools>settings>language. On this page under voice, select a voice and make sure it has the TTS next to the voice for speech. If you do not have any, you need to download garmin webupdater from http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run garmin webupdater and follow the onscreen prompts. When you get to the additional updates page, scroll down to find the voice and update the ones you would like on your unit. Once the update is complete unplug your unit and allow it to restart. Then go back to tools>settings>language and select your voice.
Sep 27, 2011 | Garmin Nuvi 265W GPS Receiver
Tip
Nuvi 265W Webupdate
Garmin Nuvi 265W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 265W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download Nuvi 265W Manuals here.
Garmin Nuvi 265W Hard Reset Here.
Garmin Nuvi 265W Favorites Backup here.
on Apr 18, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Garmin Nuvi 265W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265W Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Download Garmin Nuvi 265W WebUpdater here.
I don't know which Garmin I have but it suddenly stopped talking-volume is on-any ideas what to do?
Go into voices and try selecting a different voice.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Garmin Nuvi 265W GPS Receiver
My nuvi 265W screen keeps flashing the "GARMIN" startup logo...and wont stop
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Apr 05, 2010 | Garmin Nuvi 265W GPS Receiver
Tip
Download Nuvi 265W Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265 or 265W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin Nuvi 265W GPS Receiver
Voice command in not working
If your Nuvi 265W is not operating properly after an update, I recommend backing up your favorites and then performing a hard reset. Full instructions are below:
I hope that helps.
New WebUpdater Software here.
Dec 14, 2009 | Garmin Nuvi 265W GPS Receiver
We have 3 nuvi265w that have no voice. Also one will not pair to any bluetooth device. They had voice in the beginning and now do not. I did the update downloads and that seems to be when we stated having...
I can help you reset and fix your Garmin Nuvi 265W. If your nuvis are not acting properly after a webupdate, try it again with the newest webupdate software (available below). After backup up your favorites, and performing the webupdate, try the hard reset AFTER the webupdate. This sequence has been known to help.
  2. Download and then run Garmin WebUpdater to replace its firmware / system software.
  3. Perform a Hard Reset.
I hope that helps.
Oct 04, 2009 | Garmin Nuvi 265W GPS Receiver
Voice activation capabilities locked and none functioning after driving for 2 hours or so. Satellite reception getting lost even on a sunny day
Erratic behavior and improved satellite reception has been addressed in new system software / firmware update.
I hope that helps.
Sep 22, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi 265w
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted. Don't skip the hard reset step (or the backup step!)
I hope that helps.
Dec 25, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 265W GPS Receiver Logo
1,241 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
