Question about Fahrenheat LFP6152 Halogen Baseboard Heater
Hot electrical smell
I purchased 2 of these heaters for my sun room, and they worked very well. I then purchased another to supliment in cold weather. Now, one of the first ones is giving off a smell as if it were overheating or shorting out. There are no hot areas noticable on the heater, but the smell is persistant. I have had them for less than 4 months.
Any suggestions?
  • 4 more comments
  • sherwoodsing Jan 23, 2008
    I have the "hot electrical smell" problem too. My unit is over one year old and I have no warranty papers.
    Tom Sherwood
  • Anonymous Feb 13, 2008
    I HAVE A BURNING PLASTIC SMELL. IT APPEARS TO BE COMING FROM A SQUARE BLACK ELECTRICAL BOX 1" X 1" X .25".
  • Guest1234 Feb 19, 2008
    Fahenheat LFP6152 Halogen Baseboard Heater.
    Hot electrical smell.
    This is a bad "Diod Bridge". The cost is about $9.00. Plus shipping.
    For parts call Fahrenheat at 1-800-654-3545
  • Anonymous Jun 06, 2008
    I have these heater for my elderly father who is always cold. It worked great for almost about a yr and then it started the electrical smell. I have the box it came in. What should I do ?
  • Anonymous Nov 06, 2008
    YEA, MINE STINKS TOO. THERE IS A SMALL BLOCK WITH 4 CONTACTS INSIDE THE ELECTRICAL BOX. THE UPPER LEFT CONTACT HAS TWO CONNECTIONS AND THIS IS RIGHT WHERE THE BURNING IS COMING FROM. IF YOU FEEL THE SCREW THAT HOLDS THIS INTERNAL COMPONENT WHICH IS FOUND ON THE BACK OF THE UNIT, IT WILL PROBABLY BE VERY HOT AS MINE WAS
    HERE IS A CURRENT PHONE NUMBER FOR QMARK/MARLEY 1-800-642-4328. THEY MFR THIS UNIT.
    THE FURTHER I DIG, THE MORE I AM FEELING THIS IS DEFINITELY A MANUFACTURING DEFECT. A SERIOUS POTENTIAL FIRE HAZARD.
  • kpivideo Feb 03, 2009
    Purchased this heater in October, worked fine. Am using it in a 15 x 15 sun room. Outside air temp sometimes around zero or below. When it got that cold I supplemented it with an EdenPure (great heater). The other day I went out to the room and the room temp was 85 degrees with a very hot electrical smell. I have traced the smell to the baseboard heater. I shut both heaters off and turned only one on at a time and confirmed the smell comes from the baseboard heater. Both heaters are on separate circuits. The smell has now been consistent every time I turn on the heater. At this point I am not using it anymore until I contact the manufacturer. I am also concerned that continued use of heater could be a fire hazard.
    mkrueger@kpivideo.com
I Called 1800 452 4179 and that helped. The Manufacturer for this unit is Marley.
Posted on Jun 06, 2008
    Master:
  • 619 Answers
Before you open the the unit check first the warranty period /if open the unit the warranty will be cancelled .
The heat sensor not working in automatic / the heat exceed the limit by the heating machine the insulation keep smelling .
The small contactor might stuck due to spark and then stick together , /need to replace contactor .
Posted on Jan 10, 2008
My hotpoint refrigerator has a burning smell, it works just has that smell
May be various things.
1.- It depends on the type of weather you're living on, maybe it's a hot weather, and it adds to the normal heating that fridges have.
2.- If you have working the fridge on it's coldest point, it demands more energy, so maybe you can lower the demand of cold level.
Mar 15, 2016 | Hotpoint Refrigerators
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 03, 2012 | Water Heaters
My car doesnt want to start up right away in the morning. Almost like its really cold out and it takes it a min. The rest of the day its fine runs great. Any ideas?
Reason 1 - Gasoline, like any other liquid, evaporates less when it is cold.You have seen this -- if you pour water onto a hot sidewalk it will evaporate a lot faster than it will from a cooler place like a shady sidewalk. When it gets really cold, gasoline evaporates slowly so it is harder to burn it (the gasoline must be vaporized to burn). Sometimes you will see people spray ether into their engines in cold weather to help them start -- ether evaporates better than gasoline in cold weather.
Reason 2 - Oil gets a lot thicker in cold weather. You probably know that cold pancake syrup or honey from the refrigator is a lot thicker than hot syrup or honey. Oil does the same thing. So when you try to start a cold engine, the engine has to push around the cold, gooey oil and that makes it harder for the engine to spin. In really cold places people must use synthetic motor oils because these oils stay liquid in cold temperatures.
Re ason 3 - Batteries have problems in cold weather, too. A battery is a can full of chemicals that produce electrons The chemical reactions inside of batteries take place more slowly when the battery is cold, so the battery produces fewer electrons. The starter motor therefore has less energy to work with when it tries to start the engine, and this causes the engine to crank slowly.
All three of these problems can make it impossible to start an engine in really cold weather. People either keep their cars in heated garages or use "block heaters" to get around these problems. A block heater is a little electric heater that you plug into the wall to keep the engine warm.
i hope it was convince answers
May 30, 2011 | Dodge Stratus Cars & Trucks
About every two months the the hot water gets a sour smell. To get the smell out I turn both elements all the way up for 3 hours then drain the water heater, its good for about two months. The water heater...
The smell is from bacteria. The high temperature kills the bacteria. Some regions require water heater temp to be set at 135 because of bacteria.
A test to determine if only the water heater is causing problem: Turn off water to water heater. Smell water coming out of cold tap. Turn on water to heater, smell water from hot tap. If only hot tap smells, then water heater is suspect.
Another way to handle the problem long-term, is to reconfigure cold water pipes so you can regularly pour in 2 bottles of hydrogen peroxide during your flushing procedure. Pour in the hydrogen peroxide and let it work for a while. And then flush tank as you have been doing.
You should read up on anode rods also. Many people replace anode rods when tank begins to get odor.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
Sulphur smell
you can remove it but this will not fix your problem, you must cut the cold side pour in about half gallon of bleach ,drain heater of a gallon and a half first, then pour in bleach wait one hour then use as normal. you will have a bleach smell for some time but this will make the egg smell disapate.try this it worked for me.
Jul 21, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Electric cord becomes extreamly hot when using a very short time.
the wife is right you have a problem with heater or electric supply to heater dont use it
Mar 12, 2009 | Heating & Cooling
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Heater!!!
I am experiencing a similar problem with my Mitsubishi slimline MSH09TW unit; about 4 years old; It use to give us very hot air now it is giving some what hot air; northeastern USA current temperature about 15F. You think frigid weather in Cranbury NJ could be responsible or some thing else is going on. Please help me if you have some time and knowledge about Mitsubishi heat pumps. Sincerely, DSS
Oct 31, 2006 | Mitsubishi MS12TN Air Conditioner
Fahrenheat LFP6152 Halogen Baseboard Heater Logo
588 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
