Question about Nikon Speedlight SB-600 TTL Flash
My flash is firing, but my photo is not recording the flash output. The photo is dark as though there was no flash.
  • 685 Answers
  1. Make sure the contact on the flash and the top of the camera are clean.
  2. Check the exposure compensation (+-/-) on the camera and flash. It should be set to 0.0
  3. Make sure the camera is set on P, A or S or manually set to the correct synch.
  4. Make sure the camera is compatible with the flash.
  5. Check camera lens function to make sure the aperture is opening and closing correctly. Some older lenses (AIS, AF or non-G lenses) will need to have the aperture locked on the largest f number.
  6. Make sure the lens is compatible with the camera.
  7. Take lens cap off camera
If none of this works take everything to a local camera shopp for them to diagnose the problem and send off for repair.
Posted on Nov 21, 2009
When my OM-D 10 is in "P" mode the flash fires but the pictures are very, very dark, obviously underexposed. What's wrong?
"P" mode in most digital cameras is, "Program", meaning that it's really kind of manual. Attempting to shoot flash in this mode is likely to be difficult. Suggest "A", or "Automatic" mode.
Oct 31, 2014 | Olympus OM-D E-M10 16.1 Megapixel...
Lg ku990 flash will not fire when i take a photo in the darkness.
my lg viewty flash doesnot work therefore image is always dark.......please suggest a solution
Nov 18, 2010 | LG KU990 Viewty
Indoor picture are dark when using flash---seem like the flash and the camera are not in sync minolta 7d digital camera
If you are in Manual Mode and you set your shutter speed too higher (ie above 250th sec) the shutter blind passes over the sensor when the flash goes off causing a dark section in the photo. Lower the shutter speed to get a better sync. Some camera's default sync speed is 1/60th of a second and sometimes user adjustable.
Remember the longer the shutter speed, the more light will register in the photo. Also boosting the ISO will help extend the flashes range and also record more ambient light for a more pleasing and balanced photo.
Sep 04, 2009 | Cameras
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
INSIDE PHOTOS ARE DARK AND GRAINY
Regardless of the camera make/model... dark, grainy photos are usually a result of a lighting problem. Looking at the specs for your camera, the flash is only speced for 4m. If you are shooting near or above this you might have trouble. I ended up using an external flash that is triggered by sensing the cameras flash. Pretty inexpensive and pics ar 10x better. Try a local camera shop or B&H Photo (NYC) is where I got mine set up on line.
Jul 24, 2008 | Canon PowerShot A630 Digital Camera
RECORDING A VIDEO AT NIGHT
The flash unit is for still photos only. By design it can not be used when shooting video, because it can not stay lit (the flash fires from a stored electrical charge, and needs time to build up another charge).
May 02, 2008 | Canon IXUS 960 IS Digital Camera
SB600 Works Erratically...
If red light on flash is blinking, flash is charging. In shooting rapidly, sometimes flash will go off even though it isnt fully charged. This can give dark shots. Flash eats batteries like crazy, best to always use fresh batteries for each shoot.
Apr 14, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
CANON POWERSHOT A-85 FLASH PROBLEM
Watch the flash,(this might hurt your eyes a bit. If you are getting dark pictures the flash may not actually be firing without you noticing it. It is also possible that the output of the flash is not as high as it should be. This is not very likely though. Either way, since you have tried all posible settings, you are going to have to take it to a shop.
Mar 28, 2007 | Canon PowerShot A85 Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
103 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
