Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile CF24W-PL
Refrigerator side failure; freezer still still freezes but seems to progressively becoming warmer.
Many thanks.
Our refrigerator will not cool below 48 degrees, but freezer is working fine. We set the fridge to turbo cool, which helps, but the unit will not cool properly.
  • 290 Answers
Make sure the fan inside the freezer is running. If so, remove the cover from the back of inside of the freezer. If it is clogged with frost you have a defrost circuit problem. Most likely the defrost heater mounted at the bottom of the evaporator coil is burned out.
Post back with any questions and let me know what you find.
Thanks/Mike
Posted on Jan 09, 2008
  • Michael  Lindley
    Michael Lindley Jan 10, 2008
    Texaschick,
    Just wanted to follow up on your fridge and see what you have found out and see if you need further help.
    Thanks/Mike
  • 2,427 Answers
Its simple really,, Your refrigator needs re gassing,, call a professional and he will regas it.
When the gas is running low the fridge cools less and less and eventually will not cool at all when the gas is depleated. Its a natural process and any aircondition or refrigation professional should be able to come to your house and gas up the refrigator , a process that takes a few minutes.. I dont recommend you attempt to do it your self, as it will not take a whole can of gas and if by chance you use the wrong type you will spiol the compressor
cheers
  • Rishi Roshan Ali Jan 09, 2008
    HOW AM I CERTIN OF THIS, cause
    1.) you said the refrefation side isnt working
    2.) you said the freezer side is getting warmer
    3.) cuase its a common problem
    4.) cause i had the same problem last week :(
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
My refrigerator is getting too cold and freezing the products inside. I've lowered the temperature to 3 but it is still freezing. The water in the door is also not dispensing.
yes try the other knob make freezer colder it will make ref warmer.. what that knob does is lessen or makes more cold air come from freezer. less cold air should warm ref up. ok try that. later gator
Feb 18, 2011 | GE Profile PSW26P Stainless Steel Side by...
My daughter's GE Profile performance TPS24PPBGRS side by side is accumulating ice at the bottom of the freezer. Can you help us with this problem? Everything else seems fine. Thank you
I had the same problem. Check the hose that feeds water to the freezer. Mine had cracked and was leaking to the bottom and freezing. good luck
Aug 27, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile side-by-side Refrig (model PSW26PSSB SS). The freezer does not stay cold. Often my food thaws. I?ve placed a cup of water in the freezer over night and it does not freeze. My ice maker...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
GE Profile Side by Side Refrigerator
This is probably the ice maker water feed becoming detached from the back of the appliance. This is a fault of a leaky watervalve or low pressure allowing water to drip into the feed pipe where it freezes building up until the pipe blocks where water pressure causes it to bacome detached. Change the water valve and refit the pipe ensure there are no airleaks into the freezer.
Jul 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
423 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
