Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Just stopped freezing....so i unplugged it...then plugged it back up and it ran for about a week....then done the same thing- quit working...so i unplugged it again....then plugged it up again and it worked for about a week......??????
  • Kenmore Master
  • 43,501 Answers
Sounds like the defrost timer is not working. When you unplug it it will defrost and then as it runs it frosts up again till it stops the air flow and ....
Either buy a new defrost control and install it or have a new one installed by a tech.
Posted on Nov 15, 2009
Hello, my frig gets real cold but one day compressor stopped frozen stuff started melting. unplug plugged in few hours later it works for a week off again cycle continues for a few weeks. I replaced the...
0ba250e7-c31b-40ec-b003-ff0da31d62e4.jpgThis could be caused by a couple of things. If the condenser fan is defective and stopping while you don't see the fan stop it will cause the compressor to overheat and stop. The other possibility is a defective=> 12784415 Main Control Board or JAZZ Board A defective relay on this board will cause the same symptoms, Sea Breeze
I am here if you have questions...JT
Sep 21, 2013 | Maytag Refrigerators
1997 Kia Sportage Misfire on Cylinder 3
The injector is bad , internal coil when heated shorts out . Feel lucky it's only one injector . It could be like this corvette all injectors Quit when hot ! Test the injector with ohm meter . Chevy Corvette No Start When Hot The Diagnosis
Mar 03, 2017 | Cars & Trucks
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Just stopped freezing....so i unplugged it...then plugged it back up and it ran for about a week....then done the same thing- quit working...so i unplugged it again....then plugged it up again and it...
Did you remove the cover in the back of the freezer section?, see if the fan motor is turning, if the fan is not turning you will need to replace it and this will correct the problem allowing the air to circulate.
Nov 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Mine records and then stops after about 2 minutes
I had to modify the resolution and framerate settings to a lower level to make mine work reliably using 4 cameras. Otherwise mine would do the same thing as you have described. Once I lowered these it has worked but still locks up recording on occasion. I check it as least once a week to make sure it's still recording. When it locks up, the video remains, but the time freezes and the recording stops even though the recording light remains on.
Aug 14, 2009 | Samsung 4 Channel Dvr
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
