Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Where do i replace the bulb on the Grand Wega KF-50WE610? Is there a panel? Very new to this!
    Top Expert:
  • Sony Master
  • 14,553 Answers
Most of these sets the lamp is replaced from the front of the set.
FIRST: UNPLUG THE TV!
The piece under the screen that goes all the way across has to be removed. If you look at the back on either side and see a black plastic knob--they can be turned by hand until out(they do not come all the way out).
With them unscrewed, grasp the front edge of the grill on one side and pull it out---it will not come out gently---once one side is part way out repeat the process with the other side---then you have to get a hand under either side and pull---other then the two hand bolts it is secured with large plastic pegs--some models also have wedges at the top---once the sides and bottom are free you lift it up from the bottom and pull it off.
With the plate off you will see the lamp door--one or more screws will secure it. The lamp is inside in a cartridge with a handle---two silver allen bolts secure it---the will back out but not come out---attached to cartridge. With the bolts loose---get a hand on the handle and slide the lamp out.
With the lamp out and or with a replacement lamp-DO NOT TOUCH THE FACE OF THE LAMP WITH YOUR HAND---LIKE the Halogen lamps oil from you skin can damage it.
Most of the SONY replacement lamps come with the allen wrench.
If you have questions or need help--reply to this posting here---I am here to help people.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Have a kf-50we610 that I just replaced the bulb on but I still have nothing but vertical lines
The lcd panel may be faulty or one of the polarisers may have gone. May cost £300 to fix. May need to look at a new projector.
Hope I was of assistance
Aug 03, 2011 | Sony XL-2100U Projector Lamp for...
Is the KF-50WE610 blub compatible with the kf-e50a10 bulb
Unfortunately it is not. The bulbs of the two models are completely different sizes and shapes. You can buy the correct parts for your television here:
http://www.partstore.com/Model/Sony/Sony/KDF60XBR950.aspx
Feb 24, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Trying to change the lamp in my tv can u tell me how it a Sony 50 in kf50we610
i have a KF-50we610 sony tv and the bulb went out and i have a new one and am trying to replace but cant find where it goes in at. How do i take the tv apart to get the replace the bulb?
Dec 01, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
I have read that OEM compatible LCD Rear Proj bulbs don't typically last as long as the OEM name brands... is this true? I have a Sony Grand WEGA KF-50WE610 I see bulbs w/complete housing units at...
The answer is yes and no. Typically OEM compatible or OEM equivalent lamps last as long as the original, but you have to remember that since it isn't the XL2100u that it's not guaranteed to work the way the OEM lamp does.
Every reseller doesn't use the same specs when they put the lamp and housing together, some of the bulbs aren't always going to be up to the specifications of the OEM, but it will fit in and work.
The best tip I can suggest is to buy a lamp from a store with good warranty, so if something does happen after you bought it, you have some recourse.
Jan 25, 2008 | Sony XL-2100U Projector Lamp for...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
