Question about Sharp Aquos LC-32D40U Television
I Hooked up my PS3 TO THE HDMI input slot and it reads not compatibile with the signal
  • 405 Answers
Try to decrise output signal resolution from PS3 to 720P,
Posted on Nov 15, 2009
No signal input ps3
Try that PS3 on another TV or monitor with an HDMI input to check the PS3 is working ok. If it is try a different HDMI cable.
Dec 16, 2013 | Panasonic VIERA Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have plugged my hdmi cable to both tv and ps3 but it says no signal???
hi,
Welcome to fixya! here's the thing with this no signal issue on your TV hooked up on an HDMI try to double check physical conenction and make sure your on the right input, say for ezample if it is hooked on HDMI 1 input should be set as well on HDMI 1.
Hope this would help you
Thanks
Apr 12, 2011 | Daewoo DLN17D3 Television
Hook up ps3 and appletv to my tv - i have a Sony receiver w/HDMI slots that i am using for the PS3 - i have hooked up the Appletv to the HDMI input 2 on the back of the TV. The PS3 will not show video - i...
There are generally three HDMI slots at the back panel of an HD TV. Make sure you have connected the PS3 and the Apple TV in two separate slots. Sound will work because you must have hooked it up in Audio IN at the back or if you have connected the red and white audio cables in the front panel , the audio will work only on the camera setting on your TV
Feb 06, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
Denon AVR 3806 Philips 42PFL3603D/F7 Compatibile
Make sure the control feature is disabled on both units so that they are not trying to send control signals to each other.
Secondly make sure your input is configured to hdmi for both audio and video within the receivers on screen menu The receiver usually auto senses the digital audio signal but doesn't automaticly know that it should use hdmi for video.
Dec 19, 2009 | Denon AVR-3806 Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
Televison & Video Logo
179 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
