Question about JVC AV-36F802 36" TV
JVC AV-36F802 Shuts off after turning on, then red timer on light flashes.
This set started out with a few white horizontal lines across the top of the screen and then over time the number of lines increased until there was about 6 or 7 inches of them across the top of the screen. Then one day the set was turned on and it shut itself off, next the red timer on light started flashing steadily. I tried unplugging it for a day and then plugging it back in to reset it, to no avail. Now all it does is shut itself off when plugged in and the red timer light flashes. My wife said it had shut itself off in the past.
I am pretty good with electronics and would appreciate any help pointing me in the right direction. Not sure if the set has one problem of two. If you could suggest component(s) to check and or an area of the circuit board I would be very grateful.
thanks in advance :-)
  • 579 Answers
You are describing Vertical sweep failure.
It will be an I.C. with a part number that probably starts with an LA_ _ _ _ and be on a heat sink in the vicinity of the connector going up to the yoke. Try replacing that. But first, check all the electrolytic caps around it for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. May have lost power to the I.C. as well. Look the I.C. up in the free NTE cross reference at nteinc.com Get a diagram of its pinout to find what pins the power and outputs are on.
Hope ya fix it!
Posted on Jan 09, 2008
6ya staff
SOURCE:
Lines on top of screen jvc 36 inch model AV-36f802
Check and replace all the electrolytic capacitors at the vertical output section circuit. Replace the supply smoothing electrolytic capacitor to video output supply voltage.
Mar 06, 2013 | JVC AV-36F802 36" TV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
JVC AV-32F702 Color TV shuts off after I power it on.
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | JVC AV-32F702 32" TV
Panasonic tx51p100h shows horizontal blue then shuts off
la fuente de alimentaciom y vulve a revisar minuciosamente le convergencia poedes tener una resistencia elterada o abierta
Aug 26, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
JVC AV-K21TR
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
On timer light on
do you see a horizantal line across the screen before the set goes off. if you do, you have a problem with the virtical ic. it has to be changed. let me know if you see the line across the screen and I will show you what to do
Feb 14, 2007 | JVC AV-36F802 36" TV
JVC AV-36F802 36" TV Logo
115 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
