Question about Kenmore 44102 Front Load Washer
Will not spin on final spin - Kenmore 44102 Front Load Washer
  • 3 Answers
My GE had same problem. AFter looking on this website, I found out how to clean the filter. You wouldn't believe the rat's nest of stuff I found! Plugged it back up and it spins like a dream now.
Posted on Nov 15, 2009
Why is it that i only have a low and med final spin and not a high speed final spin after replacing the motor and thr shift clutch?
somthing to do with motor pick up coil allignment
the coil on the back needs it position set as per the service manual allignment check the clutch is fully engaged
also check brake isnt on a bit
etc
orrrr a contact on the motor connection plug is a bit burned...
Dec 08, 2014 | Speed Washing Machines
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Frigidaire front loading washing machine will not do final spin
If you cannot manually turn the tub when it is off, and not in use, then the motor and transmission is possibly seized. If you can turn it with no issue or noise, then the control is not communicating correctly to the unit.
Dec 28, 2012 | Frigidaire Washing Machines
Won't final spin ?
What is the model number of your unit?
Nov 04, 2012 | Washing Machines
My washer works until the final spin. I have tried every final spin cycle, balanced the load, removed things to make it lighter, let it rest over night, and it still stops at final spin.
The PCB (electronic board) could have failed, but there could be other problems which would have to be rectified by a technician.
Hope this helps you?
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont go into final spin
The final spin on this model requires an additional lock from the computer to the door. Remove upper rear panel and look at board. Find the tiny resistor that says R-11. If it's burnt looking the board and the wax motor (at the lock) need replaced
Mar 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore 44102 Front Load Washer Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
