Question about Cell Phones
My granddaugher had her g1 in her back pocket and was leaning against a wall. her screen is now has verticle lines.
I threw my phone at a wall and now the screen has lines of different colors on it. what do i do to fix it?
Sorry, but there is no way to fix this yourself. The screen will need to be replaced, usually cost around $100-$150, depending on the phone. Once again, sorry that it can't be fixed easily. Happy Holidays!
Dec 07, 2013 | Samsung Cell Phones
Have a calypso elite kenmore washer that will not drain. How do I get the cap to agitator off and how do I clear that line or access the drain line, this is an older top loader.
The pump is accessed from the bottom. Lean the machine back against the wall and remove the lower panel. You will likely need to replace the pump assembly. The original pump style has been changed.
Kelly
Mar 22, 2011 | Washing Machines
Viewing oil indicator Suzuki Boulevard C90 (2008)
either get a bike lift or centre stand or lean the handlebar against a wall, you will find a spot where it is close to verticle.
leave the side stand down so it cant fall on you if it over balances away from the wall
Jun 23, 2010 | 2008 Suzuki Boulevard
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
How do i clean the filter on an LG Tromm front loader?
The pump filter is accessed via the small hatch at floor level. It can also be behind the kick plate..Unscrew the filter and clean. It may be very badly clogged with whatever is left in pockets. Remember when the filter is removed the water will drain out..Also, check that coins haven't jammed the impeller. Leaning the machine back against the wall will stop the last of the water from draining and will allow better visual inspection...Good luck...Nomess
Apr 23, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
October 21, 2009 Same problem. No physical violence whatsoever. Never been dropped. One month old phone. Screen cracked.
warranty voided, had the same thing with my at&t samsung rugby, is supposed to be tough and able to withstand water temp and some shock. I guess it doesnt take much to crack these lcd screens. I've been trying to rationalize how mine cracked, maybe i had it in my pocket and leaned against a sharp counter or table top - I just dont know?
Oct 22, 2009 | Cell Phones
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
G1 phone sound issue
well throw ur phone against the wall dat made my phone work but there is a catch u will scratch it a little bit good luck
Dec 12, 2008 | HTC G1
Verticle line on the screen
Hi!!
I think that it's a hardware problem!!
Aug 26, 2008 | Computers & Internet
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
