Question about Hunter 34356 Humidifier
Where does the filter go - Hunter 34356 Humidifier
    President:
  • 1,515 Answers
Check this site out for information on where you're filter goes. They deal with this make and model for Oem wick Hepa filters, and should be able to help you out with this. Just a link for you.For model #34356, Hunter www.Filtersamerica.com
Gook Luck, and I hope they may be of some help on this.
Shastalaker7
Posted on Nov 15, 2009
Need manual for Holmes humidifier model HM-220. Don’t see replacement filter numbers on Amazon. Is there another that will work
For a manual, try Googling (holmes)(HM-220)(manual) without parens.
Fixya is unable to advise regarding filter interchangeability.
May 12, 2018 | Humidifiers
I need the air purifier filter for a danby dhcc6020
You may be able to use filters from the stove overhead filters.Stove suppliers sell filters which can be cut to size.
The filters are usually the same as those used for air conditioners.
Feb 02, 2013 | Danby PHD DHCC6020 3-in-1 Home Comfort...
CF is displayed on my humidifier...what is that?
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
Mar 05, 2011 | Bemis 826 800 Humidifier
Changed filter and it still says "clean filter" on the gauge-?reset button
not sure if there is a reset button if not
I would say if the filter was bad enough some of the foreign materials (particles the filter should capture) may have went on down the line.
the "clean filter" indicator is most likely activated by the volume of flow. So when the filter is full the flow is reduced in turn the "clean filter" comes on.
so if filter has been replaced and there is no reset button try backflushing the lines. If the lines have built up blockage your flow will stay low and the "clean filter" will stay on.
on these lines there may be bends and turns most likely to have build up in these areas restricting your flow
clean lines (low air pressure may work easiest)
Mar 03, 2010 | Sunbeam 1117 Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
How can i change the filter? I bought a BCM7207- used, and has the filter separate. where does it go?
the filter goes under the base. when you take the tank off you should be able to remove the reset of the unit off the base. inside you will see a round part that has your current filter on it. that's where the filter goes. now if there isn't a filter on it already and you have one that's where you put it. if you have any more questions please feel free to ask.
Aug 27, 2009 | Bionaire BCM7207-U Humidifier
Hi, I just recently purchased a Vicks Cool Mist Humidifier V400 Series. Could hardly wait to get it working. Problem,it did not come with the filter, box doesn't say not included. I have called around, and...
http://www.filters-now.com/products/uvk.html#UFK04=UVK
here is the website that you need to order the filter. the filter model number is k04. right now i'm seeing the filter as being 5.99 before shipping and handling. if you have any other questions please feel free to let me know.
Apr 19, 2009 | Vicks Cool Mist V400 Humidifier
Filter dries out
2 things could be happening.
#1. Your water has gotten harder in the last year and more deposits are getting caught on the filter. Try soaking it in water and vinegar for an hour. This should clean some of the deposits out and extend the life of your filters. Everytime it gets hard try soaking it.
#2. Your machine is running out of water before you can refill. When this happens and the filters dry out, they aren't as good afterwords.
I would advise trying to clean them with vinegar and water and making sure your machine is always full.
Good Luck.
Feb 20, 2008 | Kenmore 14410 Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Hunter 34356 Humidifier Logo
99 people viewed this question
Top Hunter Humidifiers Experts
Vernon Taylor
ka4iup
ka4iup
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
