Question about Sony Playstation 3 (PS3) Console
If I have a router in my home, how do I connect to the internet with my PS3?
    Problem Solver:
  • 5 Answers
I don't know if you have the old form of internet where a lot of noise is made before establishing a connection but if this is the connection you have i think you can't get a connection because the IP is changing constantly each time you try to tuse the internet.
Assuming you have a wireless router and a modern internet connection. to connect to the internet i would do it wirelessly, not only does this save the hassle of having to plug and unplug one cable to and from the modem to the PS3 but also it saves you having a big mess of cables.
You should set up a network in your home as this way the PS3 might be able to detect this and attempt to connect to this network (assuming it finds a network). if however it does find a network you will need to input a form of password that allows access to the network to be able to use the internet. This can be usually found in the setup of the router which can be accessed by typing it's IP address into the address bar of your browser. for me the IP address of my router is written under the router itself but i don't know if yours is as well.
Once in the setup search through the options till you do find something like 'pass-key' and there might be a list of them which ever is chosen you must input that same password exactly as written in to the PS3 and hopefully you can connect to the internet.
Posted on Nov 15, 2009
Cant connect to netflix error code 80130182
Without knowing more, sounds like you need to check the PS3's WiFi settings to make sure the unit is really connected through your home internet service's router to the internet. Make sure the WiFi protocol on the PS3 and the WiFi password validate correctly in the Settings, and that they match that you have set on the WiFi setup of the ISP's router. With a mismatch here to the WiFi settings, nothing on the PS3 will connect to the internet. If it all checks out but the unit doesn't connect to WiFi, if other devices in your house do and you have matched the settings, could be an indication of a problem with the PS3 hardware, scope of which to help you resolve is beyond this forum.
Feb 13, 2015 | Sony Playstation 3 (PS3) Console
Tip
How to connect your PS3 to the internet
In this guide I will go over the steps you need to take in order to connect your Ps3 to the internet either wired or wireless.
Wireless Connection
-Your home router should be configured for wireless and you should know your wireless routers security information. Make sure an Ethernet cable is not connected to the PS3.
-Turn on your console and select Network Settings under the Settings option in the main menu.
-Select the "Internet Connection Settings" tab and then select Yes when prompted.
-For the installation type select "Easy"
-Select "Wireless" when prompted for your connection type.
-Select "Scan". Your system will scan and show all available wireless access points within range.
-Select your home access point from the list.
-Select your security settings and enter your encryption key. Save your settings
Make sure to select Test Connection to make sure the connection is working properly.
<iframe src="http://rcm.amazon.com/e/cm?t=boobsbeerandg-20&o=1&p=12&l=ur1&category=videogames&banner=1P92M72BVQ4PVPEF0E02&f=ifr" width="300" height="250" scrolling="no" border="0" marginwidth="0" style="border:none;" frameborder="0"></iframe>
Wired Connection
You will have the same steps as a wireless connection, except once you select "Easy", you will be prompted for your wired connection settings. Normally, in a home environment, you are using DCHP and the IP address as well as DNS information is all obtained automatically from your router.
Be sure to select Test Connection afterwards
Ok. You should now be connected to the internet. Enjoy!
G33k
on May 11, 2011 | Sony Playstation 3 (PS3) Console
Just bought my kids a ps3 but we cannot figure out how to connect it to the internet?
Any of the two will work it all depends on preference. If the modem or router is too far from the console then you would most likely want to go wireless. Here are instructions how to do each:
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
What do I need to connect the PS3 to the internet so my boys can play online ? Hardline or will WIFI work ?
WIRELESS (WIFI):
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
No puedo conectar mi ps3
WIRELESS (WIFI):
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Feb 19, 2011 | D-Link DIR-300 Wireless Router
How can my router detect my ps3
Hello mrdjfred
Turn on you PS3 and from the home menu select Network settings , then select internet connections settings. Now select Wireless then Scan.
your PS3 will look for an access points and list them. Just select your routers SSID and password(if any)
Dec 28, 2010 | D-Link AirPlus DI-524 Wireless Router
Iam trying to connect my ps3 through a ethernet cable on my home pc it finds the ip address but no internet connection
try to connect yur ps3 to your router and not on your home pc. if your home pc has 2 lan ports then you you have to bridge the 2 lans
Sep 15, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 120GB. Recently installed Hi-Def and wireless in home. The wireless router is not in same room with PS3. Is there a device I can add to the PS3 to enable the wireless features, or does it have...
there is already a built in wireless device for the internet. id say its not working because you need to put your I.P adress, subnet mask, router and DNS numbers into playstation. go to settings on ps3. then network settings. manually install all these numbers. you should be able to get them off your laptop or computer when its connected to the internet. if you cant ring your internet provider to grt them.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
My ps3 keeps saying it can't obtain my ip address. Why is that? and how do i solve this problem
this is because when you hook up a internet cable to the ps3. its searchign for a connection.
You may be behind a firewall or router. you probably need your router password put in if you are indeed using a router. Otherwise if your not hooked up to the internet you have no need to go to "Network" in the consoles homepage.
IP address is your personal connection address on the internet. Assigned by the company you rent it from for you Home internet connection.
Hope this helps.
I hear Resistance 2 for ps3 is gonna be amazing Have Fun!
Feb 03, 2009 | Computers & Internet
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
