Question about Garden
Stihl backpack blower starter rope is pulling harder and harder. When it dose pull it starts right up.
  • Roland W VanLue
    Roland W VanLue May 11, 2010
    Model number of blower please. thanks, STIHL Gold Certified Technician, rwvanlue
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
See if your rope pulley is opening up and allowing rope to double over on itself.When this happens the rope will wedge in pulley causing it to pull hard.
Posted on Nov 15, 2009
Stihl BG 55 Blower Starter Rope Won't Pull.
indications are that there is insufficient oil in the mix and the ring has failed and jammed
you may have to pull it right down or simply junk it
if it has been discontinued then parts may also be scarce
Sep 24, 2016 | Stihl Bg 55
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
My pull cord on my Stihl gas backpack won,t pull out unless i have taken out thesparkplug
This tells me the cylinder is full of gas from needle sticking open in carb,causing it to siphon fuel in from tank when shut off, a bad cap or fuel vent will also cause this. need to tip upside down and pull rope several times with spark plug out to get all the fuel out of crankcase/and cylinder....This is causing hydrolock.
Oct 31, 2011 | Garden
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
Broken pull rope on 125BT Backpack Blower
Most small engine shops and big box stores like home depot sell generic replacement starter rope. If you want the exact part from Husqvarna, there are 2 engine variations for the 125BT. The rope for the AC57 enigne is part# 531009567, the rope for the AC55 engine is part#531009653.
Jan 04, 2011 | Husqvarna Forest & Garden 125bt Backpack...
I have a stihl br340 backpack blower that stalls
pull fuel intake line and blow through it to see if filter in tank is clogged, also the vent in fuel cap may be blocked up, try runnig it with fuel cap loose to check for this, if this doesn't help, prob gonna have to tear in to carb
Apr 21, 2010 | Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
The best way to start cold husqv leaf blower 145
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
